Author Topic: cherokee xj from 3" to 4.5"  (Read 1164 times)
Offline anjoxj98
« on: December 20, 2012, 08:35:10 PM »
Hi , I am lifting my xj 4.5" , she's actually 3" now ... I am planning to install 1.5 shackles. And 1.5" in the front , new brake lines , new track bar and lower control arms. , but I need to now if I have to change the driveshaft ?  I already drop the T-case ..
Re: cherokee xj from 3" to 4.5"
« Reply #1 on: December 20, 2012, 11:24:29 PM »
You won't net 1.5 inches in the rear with shackles alone. You would gain half of that, maybe. Look into the addition of a small block under the leaves or better yet  shackle re-location brackets.
You might get away without having to get a new rear driveshaft with that little of a lift. My XJ was vibration free when I ran that much lift. Some people were not so fortunate and had to get a new driveshaft and SYE installed. Try it out first and see how she drives.
Offline anjoxj98
« Reply #2 on: December 21, 2012, 12:04:24 PM »
Ahmm ok.. Wow I didn't know that about the  Shackles ... Also the thing is that I need to change the stock ones , they are old and not in godd shape !  Can you explain to me why they won't get 1.5" ?
Offline Dingleberry
« Reply #3 on: December 21, 2012, 12:18:04 PM »
... I have 1.5" lift shackles on my XJ. They are a full 3" longer than stock, which translates to 1.5" of lift. And they're a better alternative to using a block under the leaf springs.
Also on my old XJ I had a 6" lift (without a tcase drop) and didn't require a new driveshaft, however as tubby suggests its hit and miss. There are many variables. You'll just have to try and find out for yourself :)
Offline anjoxj98
« Reply #4 on: December 21, 2012, 01:08:26 PM »
Oh ok , thank I will try without change the driveshaft ..... And. Installing shackles then , because it make sense that the actual measure from a 1.5" is 3"
