Author Topic: aftermarket Frame nutserts  (Read 1433 times)
Offline Marco
« on: January 22, 2013, 08:12:45 AM »
I need 3 nutserts and 3 bolts for my TJ skidplate. dealer wants $120! anyone know of a different source? thanks in advance
locked and loaded
Re: aftermarket Frame nutserts
« Reply #1 on: January 22, 2013, 11:41:02 AM »
Calgary Fastener?
Bolt Supply?
Quest?
Offline Redsonja
« Reply #2 on: January 22, 2013, 12:21:46 PM »
Ya fasteners sells both the tool and the nuts.
Sent from my atari using Tapatalk
Offline RACKMAN
« Reply #3 on: January 24, 2013, 11:40:04 PM »
What dealer did you go to and do you have a part number? I went to Courtesy Chrysler looking for this exact thing and the parts guy said there was no listing whatsoever for those nutserts...I only need one so I may be willing to pay. Thanks
Offline Marco
« Reply #4 on: January 25, 2013, 01:37:52 PM »
Awsome thanks! What tool? Don't they just tack weld to the underside of frame rail? At least the ones I ground off did
locked and loaded
Offline RACKMAN
« Reply #5 on: January 25, 2013, 03:24:10 PM »
Can you tell me what dealer you went to? Thanks.
« Reply #6 on: January 25, 2013, 03:53:54 PM »
It's a bit confusing in the Mopar parts listing but try Mopar part numbers 06507904AA or 06506629AA for the bolts and rivnets.
Offline Marco
« Reply #7 on: January 25, 2013, 08:45:09 PM »
i also have two part numbers from mopar, of which their exploded views dont actually show the numbers of the nuts and bolts. it was # 19 or so. but either way i spent some time with a knowledgable parts guy there and its still $21 per nut and $15 per bolt. i concluded those prices as nothing short of halarious (but not suprised) and decided to look for another source. this is a common issue with every yj cj tj skid plate and instead of welding washers and nuts to invent threaded holes i would like a quick solution after the originals are popped out. i shall check calgary fasteners tomorow! thanks for any input.
locked and loaded
Offline LLYJ
  • carport ghetto fab
« Reply #8 on: January 25, 2013, 08:45:41 PM »
I bought a couple at Renfrew - they knew exactly what I was talking about
05 Dodge 2500HD hauler
