Author Topic: Fender flares issue  (Read 1414 times)
Offline EviLAnTo
Fender flares issue
« on: February 02, 2013, 02:58:32 PM »
On my 2000 tj sport I've managed to get off my driver side rear fender
And I'm trying to mount my newish bushwacker flat flares, I've been reading the
Instructions and it says to mount to factory nuts. Now my problem is I don't have
"Factory nuts" and I cannot get to the inside to replace the "factory nut", does anyone else have the flat
Flares? Or have had the same problem? Any suggestions?
Re: Fender flares issue
« Reply #1 on: February 02, 2013, 04:35:30 PM »
Did they not give you 16 "flange nuts"?
Offline EviLAnTo
« Reply #2 on: February 02, 2013, 06:08:18 PM »
i think i might be confused im trying to get the rivites out i grinded them off
and im trying to attack the bracket closest to the drivers door rear flare but theres nothing i can screw into,
and i cant get to the inside of it because its behind welded steel.
« Reply #3 on: February 02, 2013, 07:41:29 PM »
Did you unscrew the bolts for that piece or did you cut them off?
Offline EviLAnTo
« Reply #4 on: February 06, 2013, 01:52:12 PM »
i drilled them out they were riveted and just kept spinning, i think i might try to find some decent drywall anchors.
the ones that collapse and expand when you get them through, other than that i cant think of another way to secure the bracket.
its impossible to get on the other side without cutting sheet metal from the inside.
Offline EviLAnTo
« Reply #5 on: February 06, 2013, 01:54:15 PM »
« Reply #6 on: February 06, 2013, 06:11:23 PM »
Those were nutserts, in order to keep them from spinning you pull out on the flare to hold them tight against the inside of the fender. Since they got drilled you're hooped now for reusing them. Drywall anchors might be a good solution now aside from cutting out a section of your inner fender and welding it back in.
« Reply #7 on: February 06, 2013, 08:57:30 PM »
The only drywall fastener I would use is a 9/16 pan head screw. Got lots if you want some. And screw the flare straight in to the sheet metal.
Offline EviLAnTo
« Reply #8 on: February 07, 2013, 02:44:09 PM »
All fixed!!! I did some thinking and need up using
Some toggle bolts there pretty firm and the fenders
Are holing on pretty strong.
