Author Topic: sipping tires?  (Read 4322 times)
Offline Moezer
sipping tires?
« on: February 06, 2013, 11:10:51 PM »
Hey guys so i just bought some supers wampers and im thinking of siping the middle thread on them does any one have a machine i can barrow? or buy ya a case of beer?
this is a pic of my tire
thanks
Re: sipping tires?
« Reply #1 on: February 06, 2013, 11:48:47 PM »
That is a arm workout and a half, and a lot longer than you think. Give yourself lots of time!
Re: sipping tires?
« Reply #2 on: February 06, 2013, 11:50:16 PM »
I'll save you the trouble.
I'm going to assume that you already own a good utility-knife or box cutter. Use a new blade and find a small stool to sit on. Push the blade away from you and across the treadblock. Use your thumb to aid on the backside of the blade. Set your blade depth to cut almost 3/4 the height of the treadblock.  It won't look like you've accomplished much until you've driven on the tire and have applied the brakes a few times, so the sipes open up.
HTH
Re: sipping tires?
« Reply #3 on: February 07, 2013, 06:22:55 AM »
Here is one of mine.
Took me about 45 minutes a tire on a warm day using an olfa blade. Use one with the little twist knob on the side to lock down the blade for better depth control. The extra traction made it worth while.
Offline Moezer
Re: sipping tires?
« Reply #4 on: February 07, 2013, 12:11:53 PM »
i have seen the knife cutting on youtube thats a good idea, how about grooving?
some thing like this
Re: sipping tires?
« Reply #5 on: February 07, 2013, 01:00:55 PM »
Offline Moezer
Re: sipping tires?
« Reply #6 on: February 07, 2013, 02:08:36 PM »
lol does any one have the heating gun machine>?
Re: sipping tires?
« Reply #7 on: February 07, 2013, 09:59:04 PM »
Yup.
I've got a commercial-grade Van Alstine and an Ideal Heated grooving iron.  I've lost count on how many miserable Interco tires I've grooved and/or siped over the last 3 years. There's a few designs based off the Tennessee-cut I've done, and I've gone all the way to the Aetna-cut( not recommended for the street). I've got several different head and blade sizes ta boot . Each Swamper takes me about 30-45 minutes and it's murder on a guy's elbow.
Sorry, but I don't lend out specialty tools anymore, and I don't drink but I'll cut them for a carton of smokes . Yes, that sounds ghetto.
Try your tires out first before you decide to get them cut and see how you like them. Are they bias-ply? Skip on the wheel weights and balance them with airsoft bb's.
Offline Moezer
Re: sipping tires?
« Reply #8 on: February 07, 2013, 10:17:37 PM »
Yup.
well i only want to do the center grove not the side lugs I just want to cut the arrow in half that wouldnt take long alo i would be changing the rims that they are on right now adding them to a 11.5 wide rim
ill do the groving my self and get ya 2 packs of smoke and u can smoke while i grove lol
Re: sipping tires?
« Reply #9 on: February 07, 2013, 10:43:48 PM »
Hmmmm?
There is a cheaper way( and I know you'll like that), but I'm sure you already have access to an angle grinder. Use a dust-mask and safety goggles  as burning rubber is noxious and carefully cut the center lugs in any fashion you wish as long as it's straight. Pay close attention to the depth at which you cut. I've watched one guy do this and the results weren't too bad. It was smokey  as f_ck in the garage but it was cheap as borscht to do.
Just an option.
Offline Moezer
Re: sipping tires?
« Reply #10 on: February 08, 2013, 11:12:33 AM »
Hmmmm?
Just an option.
ummm i have done sone crazy stuff in my life time but the wife will kill me due to i have a brand new house lol
Re: sipping tires?
« Reply #11 on: February 08, 2013, 12:09:04 PM »
I have used a sawzall as well. To quick.
Re: sipping tires?
« Reply #12 on: February 08, 2013, 08:05:59 PM »
a carton of smokes and the OP doing the work sounds like one heck of a bargoon!
Offline LLYJ
  • carport ghetto fab
Re: sipping tires?
« Reply #13 on: February 11, 2013, 11:01:08 AM »
Hey Just Curious...
Any argument or reasoning to using a 1/16 vs a 1/4 or vise-versa thickness grinding wheel ? is one better at self cleaning than the other or anything like that ?
I can guess one makes a hell of a lot more smoke !
05 Dodge 2500HD hauler
Offline Tyn Pow
Re: sipping tires?
« Reply #14 on: February 11, 2013, 05:28:55 PM »
I used a 1/16" grinding wheel to groove a set of Swampers.
The disc cleaned fine....I think it burns as much rubber as it grinds off so yeah, lots of nasty smoke.
