Author Topic: Socket size  (Read 972 times)
Offline MOABICON
  • MOABICON
Socket size
« on: February 07, 2013, 09:58:46 AM »
Anyone know what size socket fits the nut on the
front of a Dana 30 on a 03 TJ. So, I can remove the
axle when I blow a ujoint. Or when I break the axle
shaft.   Thanks   ;D
Re: Socket size
« Reply #1 on: February 07, 2013, 11:25:08 AM »
Should be 36mm
Re: Socket size
« Reply #2 on: February 07, 2013, 11:42:17 AM »
Also need a strong arm, long snipe and a fat man. And he has to jump on it.
Offline binare
Re: Re: Socket size
« Reply #3 on: February 07, 2013, 11:49:05 AM »
Id take it apart in your garage where its comfy, break the unit bearings free and grease the outer before putting em back in the knuckle, wire brush everything and apply anti-sieze to the hub bolts and the stub shaft nut. Makes any trail repair that much easier. Don't forget to carry a couple extra cotter pins too.
Re: Socket size
« Reply #4 on: February 07, 2013, 12:39:26 PM »
If you break a u-joint and have run without an axle shaft, you still have to install the outer shaft and tighten in accordingly. Failure to do so will result in a good chance the unit bearing separating and causing lots of unpleasantness.
