Author Topic: harmonic balencer issue  (Read 826 times)
Offline bigdogtroy
« on: February 16, 2013, 11:15:14 PM »
so today i noticed i had some noise from the motor i inspect it thought it was my fan clutch because the way it moved so started it up it was not as noisy but now sounded like rubbing found its my harmonic balance its rubbing against my timing cover.it is a v grove pulley so where can i get another one besides the auto wrecker ?.when i get under the jeep (oh and this is a 1990 yj 4.2) it seems the harmonic is separate from the front pulley i can move the balance back and forth a little with a screw driver any help thank you
Offline WagoneerXJ
  • Bagon Wagon!
Re: harmonic balencer issue
« Reply #1 on: February 17, 2013, 12:13:12 AM »
Doesn't sound good. Most auto parts stores should be able to get you one
84 Mustang GT-Built 351W 5spd
Offline JENSSEN
    • Racing For The Cure
« Reply #2 on: February 17, 2013, 10:26:04 AM »
Sounds like the rubber isolator has given up the ghost ,.. I would not run it until you replace it
www.racingforthecure.ca
