Author Topic: Starting issues in the tj  (Read 1011 times)
Offline EviLAnTo
« on: March 13, 2013, 03:13:56 AM »
It happened to me the other day and again tonight leaving work.
I go to start the jeep nothing happens, the parking brake light comes on and when I leave the key in the accessorie position then
I can hear a clicking coming from behind the dash on the passenger side. I took the key back out and tried about four five more times then all the sudden the dash lights came on and she started up no problem.
Anyone else have a similar issue seems to happen only when it's cold out, I was thinking bad battery connection or a bad relay or fuse.
Thoughts?
Offline yellowjeep101
Re: Starting issues in the tj
« Reply #1 on: March 13, 2013, 04:08:53 AM »
Check your battery terminals, especially ground. I'd just change out terminals and clean the grounds. Then update this post
Offline binare
Re: Re: Starting issues in the tj
« Reply #2 on: March 13, 2013, 07:00:17 AM »
X2 on terminals. Had an old vw that did this, randomly wouldn't start at gas stations etc. Finally after replacing a $2 battery terminal problem was solved. Had a small crack underneath it barely visible. My point? Start simple AND cheap ;)
Offline EviLAnTo
« Reply #3 on: March 14, 2013, 12:48:11 PM »
Did both the terminals and it started no problem last night, thanks guys  ;D
