Author Topic: issues with lowering tranny skid plate  (Read 999 times)
Offline mjeep
« on: April 20, 2013, 04:43:56 PM »
I just put a slightly used 2" suspension lift into my TJ, and it came with skid plate spacers so I used them.
The height difference is causing an issue with my 4x4 shifter, I put it into 4L to tighten the front driveshaft bolts and it slipped into neutral a few times on me.  The shifter handle doesn't seem to be pulling up high enough to engage properly.
Is there a fix for this?  Is it easier to just pull the spacers back out and see if I have any vibration?
Thanks,
Mike
Offline Moezer
Re: issues with lowering tranny skid plate
« Reply #1 on: April 20, 2013, 05:04:29 PM »
drive the jeep with out the plate drop first if u get vibes then intall  the drop, as for your problem the 4x4 shifter has a linkage that you can adjust, I think it is a 10mm bolt that u loosen I got a 3.5 inch lift with no TC drop and I get 0 vibes other then my mt tires
Offline mjeep
« Reply #2 on: April 20, 2013, 05:12:05 PM »
sounds good Mouzer, thanks
Offline .:.Dingman.:.
« Reply #3 on: April 20, 2013, 05:22:02 PM »
9/16 and 1/2 wrench if you need a hand adjusting it pm me.
Dingman
