Author Topic: death wobble solved  (Read 3781 times)
Offline Corbitto
death wobble solved
« on: May 06, 2013, 07:13:08 PM »
hey everyone.  i may have just lucked out.  i changed out my steering stabilizer shock on my 91 jeep yj to the skyjacker replacement. part 7009.  and low and behold no more shakes.  rides like a dream lol.  perhaps almost a cadillac hahahaha.  even hitting a bump now at 120 on deerfoot. no problems.  of course i dont stay at that speed but still nice to feel a bit safer at higher speeds.   thought i would share since others have similiar problems.  maybe you too will get lucky.
I zip cut that tapered bolt off and drilled/ die grinded out the rest.  threads on new tapered bolt were a bit damaged so i chased them with a 1/2" 20 die.  got all bolted in and beauty.
Thanks Broken axle for the stabilizer!
Offline esi
Re: death wobble solved
« Reply #1 on: May 06, 2013, 08:07:24 PM »
I don't think you solved the issue. You've just found a better mask to cover it with.
Formerly of Boots & Boost Inc
Offline LLYJ
  • carport ghetto fab
« Reply #2 on: May 06, 2013, 08:18:37 PM »
Ditto ESI, best find what is really causing the issue !
This post requires more cowbell
05 Dodge 2500HD hauler
Offline Corbitto
« Reply #3 on: May 06, 2013, 08:48:57 PM »
solved it for now so i am happy.  no more money going into the stock diffs lol
Offline binare
Re: Re: death wobble solved
« Reply #4 on: May 06, 2013, 09:52:01 PM »
Its not solved, you masked it for now, you'll wear that new stabilizer out faster then all hell and you'll just have wasted even more money in the end. Listen to these guys they are right. If you really want to "solve" the problem, lose the stabilizer all together and start tracking down the shimmies, then replace it if you feel the need for it.
Offline Dingleberry
« Reply #5 on: May 06, 2013, 11:13:38 PM »
I can speak from experience when I say you've just found a band-aid fix.
Run it til it starts wobbling again though.
Offline LLYJ
« Reply #6 on: May 07, 2013, 02:56:52 PM »
I hope you at least take the time to properly inspect your tires, steering and hubs - Your not the only one on the road ya know, despite what some people may think driving a modified rig comes with some responsibility, and spending the money to make it safe is one of those responsibilities.  It is attitudes like that, that result in highly restrictive regulations.  Just my 2 cents, a properly running rig should not be the result of "luck"
« Last Edit: May 07, 2013, 02:59:48 PM by LLYJ »
« Reply #7 on: May 07, 2013, 03:31:24 PM »
I have no steering stabilizer right now :o
Offline LLYJ
« Reply #8 on: May 07, 2013, 11:18:10 PM »
I apologize if my last post was excessively harsh, its just that the possible repercussion of ignoring something like a hub thats coming apart is much more severe than that of something like an out of balance tire, if you know whats going on you can at least keep an eye on it.
Offline Corbitto
« Reply #9 on: May 09, 2013, 06:59:00 AM »
No need to apologize.  I feel the same way.  I would not drive or let my wife drive the jeep or any other vehicle for that matter that I felt was unsafe.  The shop checked out all my front end pieces everytime it goes in for oil or brakes etc and found no issues to be concerned with.  So I replaced the steering stabilizer and it solved the problem.  The only time it shook was the odd time I hit a bump hard enough when travelling around 100 km hr or so.  So whether its temp fix or not, it worked jeep Is driving greAt so I will take it lol.  Tires are toyos and have maybe 15000 k on em.
Offline binare
« Reply #10 on: May 09, 2013, 07:50:19 AM »
Your not listening to what's being said. If you put a bandaid over a cut, is the cut healed? No. Your Jeep ain't any safer just because it "feels" better.
Offline esi
« Reply #11 on: May 09, 2013, 08:13:38 AM »
This is just a suggestion and doesn't get done at many shops when getting mild service done. Have someone turn the steering wheel back and forth rapidly while you watch the steering components. Something will be worn and have some play in it. The new steering stabalizer will cover this up, and the wear will increase. When the stabalizer wears you might end up with a massive case of death wobble. If it was doing it around 100km before then it could be rather scary if it comes back around 100 with more play in the steering components. This is just a suggestion not meant to stir the pot.
Offline Corbitto
« Reply #12 on: May 09, 2013, 12:29:33 PM »
I am listening but when the shop tells me the front end is ok.  I believe them.  They are a reputable place that I won't name to stir up things.  So it is what it is.  I feel safe driving is bottom line and having driven, wheeled mud bogged etc with jeep yjs Over past 15 years I am comfortable with them and respect them as both stock and modified vehicles.
So obviously this topic is going no where so maybe admin just lock it out and call her a day lol
« Reply #13 on: May 09, 2013, 01:42:39 PM »
There are a lot more shops that dont know their way around death wobble then there are those that do. Period.
With the right advice, experience, and know how, anyone can fix death wobble. Specially in a YJ.
But there's nothing you are ever going to do that will fix stupid.
So ya, might as well lock this one up. Like you, its obviously a write off.
Offline Joel
  • Super Uber Web Wheeler
« Reply #14 on: May 09, 2013, 03:47:23 PM »
Your all wrong!
You need two!
