Author Topic: cj-7 lift opinions  (Read 1945 times)
Offline ferday
cj-7 lift opinions
« on: May 09, 2013, 10:05:31 AM »
i've searched, there aren't a lot of CJ threads here (or CJ's i've see around Calgary...)
i have an old 2.5" rancho from the PO, clears 33's on the street but need to swap to my 31's for even mild trail riding.  there's a good source price wise for BDS in calgary, anyone local tried their stuff?  i'm looking at a 4" kit
the other option is a small body + small shackle lift to get up around 4"...thoughts on that?  i've read a lot about shackle lifts and not excited about that, i've done body lift to YJ/TJ before so i know that can of worms well.
thanks for opinions...
Offline LLYJ
  • carport ghetto fab
Re: cj-7 lift opinions
« Reply #1 on: May 09, 2013, 11:21:00 AM »
I am really happy with my BDS lift (4" on a YJ) - double military wrap, riveted clamps with poly sliders, no sag and I've had it on about 8 years or so, with heavy bumpers and a winch - they make quality parts and have an awesome warrantee program.
Seems alot of guys do a SOA with stock YJ leafs too - poke around on Pirate, alot of CJ tech on there
« Last Edit: May 09, 2013, 11:25:11 AM by LLYJ »
05 Dodge 2500HD hauler
« Reply #2 on: May 09, 2013, 07:10:00 PM »
Bds is good bang for the buck. I believe someone has a kit to swap yj leaf packs into cj. Worth looking at if you want to lift your cj. Also look into grease able shackles.
« Reply #3 on: May 09, 2013, 09:17:30 PM »
Yes YJ leafs can be done and I think all you need to do is get the adapter shackles to go from 2" to 2.5" wide leafs
I loved my OME kit on my YJ and the ride on the street was amazing and performed excellent offroad.  I would recommend a 1" body lift and a 0.5" shackle lift.  Look at the MORE boomerang shackles.  The longer shackles will help with offroad performance
« Reply #4 on: May 10, 2013, 08:48:35 AM »
If you want some stock YJ leafs to play with if you go that route i have a set of used ones in decent condition :)
Offline snodawg
« Reply #5 on: May 15, 2013, 06:07:40 PM »
I did a lift on my CJ-7 quite a few years ago, but I used Superlift springs for a 4" lift, with H.D. Greaseable shackles. It rides okay for me, but then again it is a Jeep. I am runnings 33" tires without issues. When I replaced all the body mounts, I went with a kit that added a 1" lift as well. I could most likely run 35's. A lot more option nowadays.
81 CJ7, 302 EFI,NP435,6" lift, lockers, let's go exploring...
