Author Topic: switching a yj frame from 2.5-4.0  (Read 1043 times)
Offline Tyguythejeepguy
« on: May 09, 2013, 05:44:36 PM »
hey so I have a 1991 jeep yj and a 1993 frame and tub, the frame on the 91 is getting pretty bad so I was going to do a full overhaul on the jeep. The only issue is the 93 frame was built for a 4 cylinder and my jeep is a 6 cylinder. I am just wondering if it would be worth converting the frame or just doing rehab on the old frame. Any help would be appreciated.
Re: switching a yj frame from 2.5-4.0
« Reply #1 on: May 10, 2013, 12:59:48 AM »
you might want to elaborate on what you mean by getting pretty bad. Is it just surface rust, or is your old frame bent? Its probably not too much work to cut off the old motor mounts and weld on new ones to the other frame, but what exactly are you working with?
Offline jandh
« Reply #2 on: May 12, 2013, 11:14:21 PM »
Not to sure of all the differences in the frames between the 2.5 and 4.0 but i just finished a ton of frame work on mine, check it out.
check the link below, is this what you require?
http://www.rigidsteeloffroad.ca/phpbb3/viewtopic.php?f=13&t=2425&start=45
1991 YJ
