Author Topic: Engine cleaning  (Read 2084 times)
Offline DewaldJ
Engine cleaning
« on: July 18, 2013, 03:48:21 PM »
Is it a good idea to clean the the mud off the engine with a pressure washer or hose or just leave it?
Offline binare
Re: Re: Engine cleaning
« Reply #1 on: July 18, 2013, 04:15:20 PM »
I use simple green, pretty well a full bottle, let it soak and then use a garden hose to wash it all off.
Re: Engine cleaning
« Reply #2 on: July 18, 2013, 04:35:15 PM »
The pressure washer is fast and easy....unless all that pressure forces water into somewhere it doesn't belong. If you keep the pressure washer a godo distance away from the engine, you'll probably be okay.
Binare's method would work pretty well too - and there's less chance of getting water somewhere it doesn't belong.
Offline bullitt85
Re: Engine cleaning
« Reply #3 on: July 19, 2013, 10:01:47 AM »
i use the tire cleaner at the car wash, let it soak then spray it off. Its green as well.
Big bucket off Peigan & 25st
Offline binare
« Reply #4 on: July 19, 2013, 11:17:39 AM »
Washing your engine is never "green"
Re: Engine cleaning
« Reply #5 on: July 19, 2013, 11:37:32 AM »
Except when the copper parts are corroded.
Offline Teeka
Re: Engine cleaning
« Reply #6 on: July 21, 2013, 09:37:49 AM »
I put a tea towel in the air in take just incase I oops.  And pressure wash. Just don't forget to pull it out
Offline Sean778
Re: Engine cleaning
« Reply #7 on: July 21, 2013, 08:23:33 PM »
I never pull it out  :P
I'm always a little leery of using a pressure washer in the engine bay.  I've had mixed results on a variety of vehicles.  Water seems to find it's way into bad places regardless of how careful I am.  I often just use a rag and some degreaser, and then rinse off with low pressure, like a garden hose.  Mostly the Jeep stays dirty though.  8)
'89 XJ
Offline jkrubi
Re: Engine cleaning
« Reply #8 on: July 21, 2013, 10:52:33 PM »
I pressure wash the eng and eng bay after wheeling. I hate having a dirty eng/bay! I use the tire cleaner/eng cleaner that comes out at the car wash.  It also gives me a chance to make sure that all the mud is gone and every thing is in good shape ( belts,hoses,general condition)
