Author Topic: Engine stalling during idle  (Read 3918 times)
Offline CiaMonkey
  • Mini me
« on: July 31, 2013, 09:27:25 PM »
Hey guys so I need a hand diagnosing my jeep. Today my jeep ran fine and got me to work on the way back she started running rough while idling then stall and I Cannot save it with pressing on the gas. I figured vacuum leak and sure enough the rear tube on the top of the valve cover was ripped in half, so I got it to a parking lot and ran to the parts store. I taped it back up and still it stalled when idling at lights. It's making a loud noise in the back by the fuel tank, the tube is only taped up could it still be that or is it the noise coming from the back causing the problem? Thoughts? Also sound like the jeep is struggling for when its about to stall.
Billy
Zombie Response Team
In commission- '92 YJ smittybuilt src bumper, 2x hella 700's, 2x hella 500's, cobra CB + antenne. To come: 4" suspension lift and 33" Nittos.
Retired- '12 wrangler mojave
Re: Engine stalling during idle
« Reply #1 on: July 31, 2013, 10:31:59 PM »
Put fuel in the fuel tank. That's my first guess:)
Offline CiaMonkey
  • Mini me
« Reply #2 on: July 31, 2013, 10:49:08 PM »
I was thinking that too, might give it a shot just in case lol.
Offline BUKI
  • Project Fugly
« Reply #3 on: August 01, 2013, 06:37:43 AM »
Have you checked codes?  Do you have a fuel pressure tester? Noise from back indicates a prob with pump. Eric's got a point have you got enough gas? Don't go by the gauge. Gauge said i had a 1/4 tank and nope. Ran it dry. Does it start every time, just runs like poo?
Sent from my iProne
Offline CiaMonkey
  • Mini me
« Reply #4 on: August 01, 2013, 08:50:00 AM »
Starts but it usually takes about 20 mins of sitting
Offline JadeMonkey07
« Reply #5 on: August 01, 2013, 09:45:02 AM »
There should be a black pressure release valve on the fuel lines near the motor. You can depress this(wear safety glasses) while its running. fuel should shoot out quite far. If it just dribbles out then you need a new pump
Offline CiaMonkey
  • Mini me
« Reply #6 on: August 01, 2013, 09:47:15 AM »
cool ill give that a shot
Offline fug
  • Airdrie Pick n Pull
« Reply #7 on: August 01, 2013, 10:16:12 AM »
Idle problems and not restarting for a period of time makes me think Crank Position Sensor (CPS).  A bad or failing CPS can manifest its self with rough idle and stalling out once it gets hot.  Eventually it fails completely and you can't get it to start at all.
Fug
TJ Rubicon
Offline CiaMonkey
  • Mini me
« Reply #8 on: August 01, 2013, 02:41:29 PM »
Do you guys think it could be a problem with the ccv? would that cause the engine to stall? anyone know where i can get ccv's and hoses locally?  :-\
Offline mike s
  • Good times!
« Reply #9 on: August 01, 2013, 11:09:04 PM »
X2 on the CKP sensor. Prone for problems like yours. Crank case vent hoses are avaliable from napa I think. Comes complete withe elbows and hard plastic tubes. Common replacement.
Mopar sells em too. Not terribley expensive.
oldEnuff2NObetter
but still can't help myself
Offline CiaMonkey
  • Mini me
« Reply #10 on: August 01, 2013, 11:18:49 PM »
Kk thanks mike
Offline AstraX
Re: Re: Engine stalling during idle
« Reply #11 on: August 02, 2013, 12:42:46 AM »
I think all of your problems stem from the "yj". They are almost as bad as the "xj" and really the only real fix for them is to get a "tj" or even better a "jk".
« Reply #12 on: August 02, 2013, 07:07:28 AM »
Hold on Dan... Where is the YJ love?
Offline CiaMonkey
  • Mini me
« Reply #13 on: August 02, 2013, 07:54:31 AM »
Lol had a jk, cost to much. Always wanted a tj, still cost to much :)
Offline BUKI
  • Project Fugly
« Reply #14 on: August 02, 2013, 02:13:09 PM »
Don't worry, Dan is rich so he can afford a jk.
Sent from my iProne
