Author Topic: stupid ZJ tranny  (Read 2742 times)
stupid ZJ tranny
« on: August 07, 2013, 01:35:29 PM »
95 ZJ, 46RH tranny. V8.  google points towards a lot of info on the 46re but theres not much on the hydraulic versions of these trannies.
wife drove jeep into DEEP mud hole. turns out the snorkel works; tranny didn't like it. came out and no first gear.
so; after the dunk:
no first gear at all. it went in once, and shifted HARD out of first and into second; hasn't gone into first again. won't do it when i manually shift to 1 either.
also, it hangs way to long in second. when it finally shifts into 3rd its good. 3 and overdrive are good. no issues. reverse no issues.
pulled pan and fluid looked ok; no visible mud really in it. fluid cleanish; it is due for a clean though.
pulled the pan and filter; haven't put it back together yet because i'm installing a tranny drain plug; so i can finish flushing it tonight.
just looking for ideas; at work and its driving me crazy, and i'm already tempted to just gut it and find a niner.....
Re: stupid ZJ tranny
« Reply #1 on: August 07, 2013, 02:42:46 PM »
That sucks...  You should have installed a tranny snorkel too. And while you are it: axle snorkels, gas tank snorkel, washer fluid snorkel and cabin snorkel are all in order....
« Reply #2 on: August 07, 2013, 04:30:21 PM »
The water faeries do not like you Johnny. Either that, or it's your Karma for driving a Sleezy Zee.
Offline binare
Re: Re: stupid ZJ tranny
« Reply #3 on: August 07, 2013, 04:50:18 PM »
Have you parked it near a JK recently Johnny?
Offline raf2379
« Reply #4 on: August 07, 2013, 08:01:06 PM »
trade it in for an XJ. I would check range switch and any sensor wiring. any codes coming up?
« Reply #5 on: August 08, 2013, 07:52:35 AM »
Those transmissions are crap when they arent wheeled. Unfortunately, as long as you run them, you are going to plagued with issues.
« Reply #6 on: August 08, 2013, 08:36:58 AM »
i assume you mean they are crap billy? i'd agree.
fluid flush helped a fair bit.  i got first back again at least when i put it into manual mode. cycles through all gears again. seems to want to not downshift into first when its in D from a start. it willl start out in second unless i floor it. then it hits first.
guess i'll drive it like i stole it lol.
thinking its time to find a manual to put behind it.... nv3500 or maybe an AX15 if i can find that rare Dakota with the manual and V8....
« Reply #7 on: August 08, 2013, 01:25:55 PM »
yeah, they just dont seem to be a reliable transmission.
Yeah, that would be a nice swap. There's a few of those around.
« Reply #8 on: August 08, 2013, 11:15:13 PM »
Done some research. It's the route I would go....... Costly so it's gonna be a timely venture. As long as the auto can hang on for a whole as I collect parts all good..... Seems to me it will. Shifting better now at least......
Offline Donnie
« Reply #9 on: October 23, 2013, 11:06:07 AM »
Hey Johnny,
Would a 5speed out of a 2000 2wd Dakota that has the 4.7 work for you??? I know where there is one for cheap, real cheap... but it does need work. Let me know.
Donnie
Offline CatSplat
« Reply #10 on: October 23, 2013, 03:04:30 PM »
Hey Johnny,
Donnie
It would bolt up to the 5.2, but the 2wd tailshaft has no provisions for attaching a transfer case, and swapping the tailshaft requires a output shaft swap as well.
Jeep of Theseus
