Author Topic: 05 LJ, No Crank, No Start  (Read 3601 times)
Offline scott slade
  • Amboy... Route 66
« on: November 14, 2013, 10:08:13 AM »
Just when I was about to buy a new windshield..!!   Turn key, power on, no cranking or starter noise. Battery is new, starter is newer... I hear this is an issue with some TJ's.. any thoughts on a quick fix..??   >:(
2005 LJ, Six Speed,
 16" Moab Rims
Offline Moezer
Re: 05 LJ, No Crank, No Start
« Reply #1 on: November 14, 2013, 10:35:16 AM »
disconnect the batt for a bit then try again? I had a similar problem with my bmw and it turned out the keys needed to be reprogrmed
« Reply #2 on: November 14, 2013, 06:02:53 PM »
Do you have any power?  Lights, but no crank?
Offline scott slade
  • Amboy... Route 66
« Reply #3 on: November 14, 2013, 08:13:09 PM »
Full power  etc.  Just nothing when key turned to start. Fuel pump etc can be heard but not a crank. Starter and battery etc all good.
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #4 on: November 14, 2013, 10:12:06 PM »
Confirm your fuses are good. Then make sure your starter has power on crank. Then confirm neutral safety switch.
Offline CatSplat
« Reply #5 on: November 14, 2013, 10:13:56 PM »
Check your neutral safety switch, sometimes just jiggling the shifter can get things sorted.
Jeep of Theseus
Offline scott slade
  • Amboy... Route 66
« Reply #6 on: November 14, 2013, 11:45:40 PM »
Fuses Good, Power to starter on Crank...  ( not to be confused with Mayor on Crack )...  I have a feeling it may be the hidden switch in the ignition. Something about a broken bit of plastic that moves a metal thing to make the connection.  ????  There is a video on Youtube where a guy installs a starter button to by pass this glitch.....  May be the root to go to avoid a heavy repair bill or some mechanic swapping parts out and taking fun money away from the Jeep...!!!   Still a squirt off though.. I can't get to repairs until monday now anyway.   8)
2005 LJ, Six Speed,
 16" Moab Rims
Offline scott slade
  • Amboy... Route 66
« Reply #7 on: November 19, 2013, 03:50:47 PM »
Well I hit a wall, tried almost every trick I can think of.  Full power every where it needs to be, but still won't crank or click.  Anyone wanna buy a wounded LJ..... aaahhhh
2005 LJ, Six Speed,
 16" Moab Rims
Offline jkrubi
Re:
« Reply #8 on: November 19, 2013, 04:21:38 PM »
Ave you tried starting it with a jumper button on the starter motor, bypassing the key? If so does it turn over then?
Have you check the fuseable link? I had a vw that blew the link, power went threw in with a meter/test light but not enough to amps/voltage  were allowed to go thru. Same kinda deal/issue that you have right now. It was in the power line to the starter, just a thicker portion up near the battery. I cut out the link and terminated it to the battery, no more issues.
Offline scott slade
  • Amboy... Route 66
« Reply #9 on: November 24, 2013, 02:14:11 PM »
Well, even new starters go bad too....  Thank goodness for lift springs, makes it easy to crawl under and fix it up. Thanksfor the tips and advice...  She Runs...
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #10 on: November 24, 2013, 04:34:05 PM »
Damn. I wanted a cheap LJ
Offline Moezer
« Reply #11 on: November 24, 2013, 06:48:48 PM »
man oh man this happened to me last night wtf......  starter is less then a year old too, I tried to start the jeep straight from the starter all it did was spin with out engaging then just in the jeep and now works normal lol but not sure when it will fail me again :(
Offline scott slade
  • Amboy... Route 66
« Reply #12 on: November 24, 2013, 10:18:38 PM »
You can only go so far on spinning the starter with a jump or smacking it with a hammer and hoping for the best.  All these little issues add up,but one hour with the top off the Jeep in the summer makes it all worth while...!!!
2005 LJ, Six Speed,
 16" Moab Rims
Offline Moezer
« Reply #13 on: November 25, 2013, 10:01:38 AM »
lol its not only that, after I was working on the jeep swapping my front axle in took about 6 hrs because I was doing it all by my self , I changed the oil came to test it and it turned once and then that was it lol, went to buy a battery couldn't find one at Wal-Mart then im like dammit came back home watched tv but it was bugging me really bad so went back out side and fixed it was done by 130 lol
