Author Topic: need upper control arm bolts  (Read 1907 times)
Offline Fleetline
« on: December 17, 2013, 12:05:26 AM »
as you may remember i had a cobbled together jeep xj i was trying to find out what the parts were off of.  Well i gave up and put brand new leafs in it,  Bought new adjustable upper and lower control arms and a new upgraded steering system.  Well whoever built this jeep used cheep bolts not grade 8 and they were bending so i need new upper control arm bolts (grade 8).  The bolts on the axle
well really i would like too replace all the bolts new . So where can i find them? all i can find is standard and i think i need metric as they are sloppy and i can't find  anywhere that has clue where to find em.  I don't care if i have to get them online but rather just go and buy  them.  I don't believe in using the old stuff unless i have too
I have spent alot of money on it to just put the old bolts back in...thanks
Re: need upper control arm bolts
« Reply #1 on: December 17, 2013, 12:34:11 AM »
Calgary fastener
Quest
modern motors
Offline Fleetline
« Reply #2 on: December 17, 2013, 12:38:26 AM »
ty
« Reply #3 on: December 18, 2013, 09:49:25 AM »
Dealer has them as well.
Or go to PYP and get it all there.
« Reply #4 on: December 18, 2013, 09:52:02 AM »
« Reply #5 on: December 19, 2013, 05:10:59 AM »
Just read your original post again, and for Metric when I was living in Calgary Quest was usually the best place to source that stuff.
http://questindustrialproducts.com/
The address should be on their page. Otherwise, its pretty much located in the little strip mall not too far from Rockys Burger Bus
Offline CatSplat
« Reply #6 on: December 19, 2013, 04:14:20 PM »
Triad Fasteners has also been good for metric stuff.
Jeep of Theseus
