Author Topic: Heater issue  (Read 1444 times)
Offline DewaldJ
Heater issue
« on: December 23, 2013, 09:56:47 PM »
I have a 1997 TJ . The fan/heater inside only works when I turn the knob to 4. Nothing happens on 1,2,3. Any ideas?
Devo
Re: Heater issue
« Reply #1 on: December 23, 2013, 10:33:17 PM »
Heater blower fan resistor pack. Sorry no idea where it is on a TJ. Usually under the dash on the passenger side, bolted into the heater box, has a wiring harness going to it with 3-4 wires and then may go off to the blower motor.
Be advised that when the resistor pack goes its often a sign that the blower motor is going. Especially if any wires are burnt or the plug shows signs of melting.
Offline DGenR8
Re: Heater issue
« Reply #2 on: December 29, 2013, 03:06:23 AM »
Refer to this post on The Wrangler forum, has pics and everything  8)
http://www.wranglerforum.com/f282/heater-blower-motor-resistor-replacement-with-pics-133063.html
_/l ,['''`'''],
l---L--OllllllO-
81 CJ7
Offline GreenMachine
Re: Heater issue
« Reply #3 on: January 01, 2014, 08:12:58 PM »
I'm y 03 tj,
Took out the glove box, and it was kinda awkward, between the bottom of the opening and the bottom edge,
