Author Topic: dana 44 mini spool  (Read 2344 times)
Offline bradley
dana 44 mini spool
« on: January 22, 2014, 12:49:44 PM »
I want to put a mini spool in my 02 jeep tj dana 44, my question is if the axle shafts are held in by c clips or not, and if they are is there a mini spool that works with the c clips? Or do i need to get a c clip eliminator kit or smthing like that?
thanks for any help
2002 jeep tj, 7 inch lift with long arm front and triangulated 4 link rear, 37x12.5x15 maxxis creepy crawler tires, custom front and rear bumpers, 12000 winch, G2 dana 44 front with detroit locker, 44 rear with spool, custom rear skins and flares, sye kit
Re: dana 44 mini spool
« Reply #1 on: January 22, 2014, 01:34:28 PM »
just put an aussie locker in it. much easier and will be Cclip compatible i believe
Offline bradley
« Reply #2 on: January 22, 2014, 02:10:33 PM »
ya thats the plan if the mini spool doesnt work out just figured would try for mini spool cus its cheap and effective
« Reply #3 on: January 22, 2014, 03:56:25 PM »
D44 shafts do not use C clips to hold the axle in place.
Offline bradley
« Reply #4 on: January 22, 2014, 04:36:20 PM »
If u dont mind me asking how are they held in? And if thats the case i will just go full spool
« Reply #5 on: January 22, 2014, 04:51:40 PM »
Me: " Hey, I can get ultimate traction for under $60 ! "
Me again : " I can always take it out in a jiffy if I don't like it"
Reality? Wore an expensive set of tires out in one season , had to rotate tires monthly, chirped like a bastard on dry pavement and got nasty stares at Tim Horton drive-throughs.  Rainy days or ice was ...umm...interesting .
The mini-spool was also hard on my axelshaft splines ta boot.
Went selectable and will never go the spool route again on a rig that sees some on-road time. Even in a full-time offroad rig, I'd probably choose a Detroit locker.
« Reply #6 on: January 22, 2014, 05:02:51 PM »
4 bolts
Axle shaft retaining plate
Offline bradley
« Reply #7 on: January 22, 2014, 08:55:39 PM »
Awesome, thanks for the quick replies.
I appreciate the warning but i still think its worth a try,  I only drive my jeep to and from the trails so it doesnt see much road time
« Reply #8 on: January 22, 2014, 09:20:51 PM »
just weld it buddy. same as a spool and if its done correctly just as strong
« Reply #9 on: January 22, 2014, 09:49:23 PM »
Weld it. Permalocked!!!
Offline bradley
« Reply #10 on: January 23, 2014, 10:11:56 AM »
I have thot about just welding it but if I do that then there's no slavaging the carrier if I decide I really don't like the mini spool
