Author Topic: Low gas mileage  (Read 1812 times)
Offline mk333
Low gas mileage
« on: January 25, 2014, 01:37:08 PM »
For about a month now I have noticed a decline in the km's I am getting with my Jeep. I have an 2001 XJ and usually can get around 500 km's to a tank but I am getting just over 400 now. I was thinking mabe a new fuel filter might be the answer but maybe you guys/gals here might have another idea. Tires pressure is good, new air filter and doesn't burn any oil. I've been doing the same commute for 3 yrs now..Carstairs to Airdrie every day so all highway km's. Any ideas would be great.
Offline apeman
  • not as grumpy
Re: Low gas mileage
« Reply #1 on: January 25, 2014, 04:10:43 PM »
Fuel filter is built into the pump, which means dropping the tank. Have fun.
Getting grumpier every day.
Offline JENSSEN
    • Racing For The Cure
Re: Low gas mileage
« Reply #2 on: January 25, 2014, 04:26:43 PM »
Have you checked the Cat convertor, O2 sensors, has it had a tune up?
www.racingforthecure.ca
Offline whitefang
Re: Low gas mileage
« Reply #3 on: January 25, 2014, 05:25:23 PM »
agree with JENSSEN, check sensors then tune up!
clean throttle body, fuel injectors, new fuel filter
check spark plugs (if one is foiled test coil pack) change spark plugs, plug wires,
check timing.
for best gas mileage, run 215 75 r15 tires stock gears and no lift!!!
1995 xj Richmond Lock-Right front and back 2" lift 31x10.5 BFG KM 8500 superwinch
Re: Low gas mileage
« Reply #4 on: January 25, 2014, 05:56:32 PM »
Have been doing a commute to highriver everyday as well. Really windy the past month and  a half. Gas mileage in the big work van went way down as well.
Re: Low gas mileage
« Reply #5 on: January 25, 2014, 07:57:38 PM »
Just carry a jerry can..  Or 2...   Its a jeep
Offline birdo
  • 99 TJ
Re: Low gas mileage
« Reply #6 on: January 25, 2014, 09:21:22 PM »
Any chance your fuel gauge is out of whack? I would check O2 sensors for sure. They are good for about 50,000 kms then you really should consider replacing them.
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
Some Cheapo Clarion Stereo
Heated Seats, Air-Con, Cruise
230,000 kms
Re: Low gas mileage
« Reply #7 on: January 26, 2014, 09:31:08 AM »
I was getting the same 500km/tank in my 99 XJ, then I switched to synthetic oil, transmission fluid, and gear oil. Started getting about 600kms/tank. But.... Wind played a huge factor in mileage.
I was about 50/50 city/highway driving.
Offline birdo
  • 99 TJ
Re: Low gas mileage
« Reply #8 on: January 26, 2014, 12:04:18 PM »
Which reminds me.....I put synthetic in the gearbox last year and it made a HUGE difference to cold weather shifting and gear selection overall. Plus, I got rid of that stupid rubber shifter boot and replaced it with a nice soft leather one. HUGE!!!!!
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
230,000 kms
Offline mk333
Re: Low gas mileage
« Reply #9 on: January 31, 2014, 12:32:59 PM »
Thanks for all the info. I ve been thinking about going to synthetic for a while now. Spark plugs and O2 sensor are a good start.
