Author Topic: Tire Question  (Read 1401 times)
Offline canthonyparkinson
Tire Question
« on: January 30, 2014, 01:42:28 PM »
What is the largest tire size I can put on a 2013 JKU Rubicon with no lift and using the stock rims?
I was hoping to get  to LT285/70R17
Anthony Parkinson
2013 JKU Rubicon
Re: Tire Question
« Reply #1 on: January 30, 2014, 05:01:26 PM »
You can stick 35's in there if you don't mind a bit of rubbing and install some wheel spacers.
33's would be smarter - especially if you go to flat fenders.
Re: Tire Question
« Reply #2 on: January 30, 2014, 07:49:07 PM »
If you don't use wheel spacers then the 285 is a safe choice with no other mods. If you don't mind wheel spacers then 295 can fit. If you change rims then a 305 is an option. These are all close in height and just get wider. High line fenders or just trimming your stock ones can get you more room. Lots of different ways to step up in tire size. Lots of tire options too:)
Re: Tire Question
« Reply #3 on: January 30, 2014, 07:51:02 PM »
Actually we just did a set of 33/1250r15's on a stock jk. Adifferent look then most jk'sout there.
