Author Topic: Shop charge repair? Rear main and rear axle seal...  (Read 1357 times)
Offline RACKMAN
« on: February 08, 2014, 01:06:44 AM »
Looking at a jeep for a friend that needs a rear main engine seal and oil pan gasket replaced and a passenger side rear axle seal replaced. It's a 4.0L  TJ with a dana 44 rear axle. What would be the total average hours a shop would charge for these two repairs? thanks.
RACKMAN
Offline dubbleJs
Re: Shop charge repair? Rear main and rear axle seal...
« Reply #1 on: February 08, 2014, 02:28:47 PM »
I would just give a couple shops a call and they will give you a quote, they will have all the labor and part costs set already and just type it in the computer.
« Reply #2 on: February 10, 2014, 02:37:57 PM »
Did you try pulling the axle and re-installing to see if you get that seal to re-seat. Works sometimes.
All in all its about 6 hours work plus parts. Id say most shops would be at least 5-600$. I know when you do the rear seal you might as well do the bearing at the same time. More work to save it then what its worth.
Offline RACKMAN
« Reply #3 on: February 10, 2014, 03:13:30 PM »
Sent you a pm
