Author Topic: May be a silly question,... Aftermarket hella driving lights.  (Read 1233 times)
Offline JENSSEN
    • Racing For The Cure
« on: February 11, 2014, 07:48:58 PM »
I got a set of hella 500 black magic driving lights .
The OEM driving lights are shot, can I wire these to the factory harness or just use the factory harness as a signal for the included relay and harness that came with the Hella system? Don't want a meltdown or factory harness fire.
www.racingforthecure.ca
Re: May be a silly question,... Aftermarket hella driving lights.
« Reply #1 on: February 11, 2014, 07:54:53 PM »
I would go with option two.
« Reply #2 on: February 11, 2014, 07:56:11 PM »
Option drastically reduces the chances of a fire...and if you use an appropriate gauge of wire, the lights will be far brighter as well. Factory harnesses for lights tend to suck in a pretty epic way.
Offline mike s
  • Good times!
« Reply #3 on: February 12, 2014, 08:23:43 AM »
use supplied relay, if you want them even brighter wire the power feed to relay (with a fuse) to your alternator main lug. extra half volt or so. use the factory wiring to trigger the relay.
oldEnuff2NObetter
but still can't help myself
