Author Topic: flat towing a tj  (Read 2302 times)
Offline Wingnut
flat towing a tj
« on: May 16, 2014, 03:15:12 PM »
I have a 2001 TJ with a manual tranny. I am thinking of flat towing it behind my motorhome. How do I set it up? I have heard that I should put the transfer case in neutral and the transmission in gear with the steering wheel unlocked. Would that be right?
Offline EEP
Re: flat towing a tj
« Reply #1 on: May 16, 2014, 07:46:54 PM »
Try Google, that's what I did to find out how to flat tow my XJ.
14 JKU, wife's urban 4X4.
Offline Black Betty
« Reply #2 on: May 17, 2014, 06:03:17 AM »
Ever thought about buying an actual trailer?  That would be my preference.  Keep the wear to the trailer tires and not to the jeep tires.
Stupid hurts
Offline cjust
« Reply #3 on: May 19, 2014, 07:53:23 AM »
i agree, tires are to expensive and im sure u can get a decent toy hauler for $1500-2000
J ust
E mpty
E very
P ocket
Offline LLYJ
  • carport ghetto fab
« Reply #4 on: May 20, 2014, 03:19:16 PM »
yes, you heard correct.
05 Dodge 2500HD hauler
Offline ornamental
« Reply #5 on: May 20, 2014, 08:41:40 PM »
What is the logic to having the transmission in gear?
Would it be bad to be neutral and neutral for transmission and also transfercase?
« Reply #6 on: May 21, 2014, 09:04:02 AM »
That is how i towed my TJ and CJ. If you want, you could remove rear driveshaft to save wear and tear, i didn't.
Offline Tanner
« Reply #7 on: May 21, 2014, 10:14:25 AM »
I went through this last year too. The logic behind leaving the transmission in gear is so the oil pump in the still operates while the jeep is being towed. Keeps the gears/bearings lubed.
« Reply #8 on: May 21, 2014, 01:46:31 PM »
But the tranny isn't spinning if the t-case is in N.
Offline Dingleberry
« Reply #9 on: May 21, 2014, 02:01:20 PM »
Oh snap! Well put the engine in neutral instead! lulz.
