Author Topic: transmission skid plate nutserts YJ/TJ  (Read 1344 times)
« on: May 22, 2014, 08:54:31 AM »
got the three off on the passenger side with little effort; the drivers side sheared all three with little effort.
so i'm looking for the nutserts so i can grind off the old ones and put the new ones in.
i called Tower, and it seems nobody has em in Calgary, they can get me 3 in for tomorrow, 20$/ a piece.
i know the guys at Black Majic Brakes in the US make a niftly little replacement kit for specifically this, but was hoping to get something ASAP so i could at least drive the damn jeep.
anyone have this problem at some time and actually order these up? or have any insight?
cheers
Offline .:.Dingman.:.
Re: transmission skid plate nutserts YJ/TJ
« Reply #1 on: May 22, 2014, 10:17:48 AM »
Do you have to use nutserts? Can you cut out the old and use a nut and washer? What about welding a nut in place? Text me some pictures john.
Dingman
Offline CatSplat
« Reply #2 on: May 22, 2014, 07:24:31 PM »
I got my nutserts from Triad Fasteners, give them a try.
Jeep of Theseus
Offline cuzican
« Reply #3 on: May 22, 2014, 10:10:46 PM »
I have welded a crossbar onto a bolt head so that it would wedge in the frame rail to stop spinning and then fished the bolt through the frame to the hole with a piece of wire. Works okay but gotta hold the threads so that the bolt doesn't accidentally push back up into the frame when putting the washer and nut on.
I did this successfully several times until I discovered that nutserts were way easier  ;)
« Reply #4 on: May 23, 2014, 08:49:03 AM »
looked into the black magic kit in the US, it would be roughly 75$ to get it here in a few weeks.  however i am not that patient.  the dealership brought three in for me at a modest price of 20$/piece, should be here today.
benefit; at least i should be able to get it up and running this afternoon.  downfall, i literally just paid 65$ for 3 nuts.
