Author Topic: Swapping out a 2.5 for a 4.0.  (Read 1673 times)
Offline Chaddo
« on: June 01, 2014, 10:18:23 PM »
Hey guys just curious how hard it is to swap out a 2.5 and install a 4.0 ltr.  The jeep is a 98 with a dead 2.5.    Can't find one so thinking about a swap.  4.0 Cherokees are everywhere   Not sure if will bolt  in nice or if need tranny ,transfer case etc.   Any help be great
Re: Swapping out a 2.5 for a 4.0.
« Reply #1 on: June 02, 2014, 07:26:04 AM »
You'll need engine, transmission, transfer case, motor mounts on frame, trans mount, exhaust work, driveshafts, rad fan shroud, wiring harness, and a few other things I've forgotten.
 Find a similar year for best results. Find it all from a tj is ideal but Xj could work for the most part. Transfer case on Xj is clocked lower for clearance.
Offline BUKI
  • Project Fugly
Re:
« Reply #2 on: June 02, 2014, 07:27:32 AM »
What he said. Good luck
« Reply #3 on: June 02, 2014, 11:37:39 AM »
So a little less work than an LS swap but a lot less reward?
« Reply #4 on: June 02, 2014, 11:48:31 AM »
do an LS swap then you might as well just swap to bigger diffs, lockers and link suspension.  pretty sure the D35 wouldn't be happy with 400 hp. lol
« Reply #5 on: July 02, 2014, 03:39:37 PM »
It won't bolt in. You also need the ECM from the 4.0L. Your best bet it to get a rollover and buy the whole thing. Small block chevs are around the same price/effort to swap in with a lot more power but it will be much easier to break things.
