Author Topic: Anyone Run an Electric Fan successfully?  (Read 4995 times)
Offline Dingleberry
Re: Anyone Run an Electric Fan successfully?
« Reply #15 on: June 25, 2014, 11:51:30 AM »
I attempted to fit a Taurus fan but with my alternator up top  the belt was in the way of the fan motor and I gave up. Instead I installed two 97+ XJ fans on switches and have not had any issues. It runs below 100. I ditched the a/c condenser that was blocking flow in front of the rad, keep the rad clean and always have the fans running (except for water crossings, but I usually forget to turn them off anyways  :P )
The trick there is to move your rad forward about an inch and a half ;)
It requires cutting a small amount off the metal support-beam thing across the top to make room for the rad cap.
Offline Jrama
« Reply #16 on: June 25, 2014, 12:53:56 PM »
I think the Real trick for a TJ is to stick with mechanical...thank god for an iron block and an iron head. Stoopid Taurus fan ran my jeep to boil over more time then I can remember....on the trail....on the road..you name it particularly when you didn't expect it.
I'm not going to drop hundreds of dollars on a fancy fan .... not enough benefit...Taurus fan was good because the whole thing could be done for just over 100 bucks
Offline Dingleberry
« Reply #17 on: June 25, 2014, 02:44:02 PM »
Jamal it can be done for much less!
Offline Jrama
« Reply #18 on: June 25, 2014, 04:12:32 PM »
Well there you go...I payed too much for my pain in the arse
« Reply #19 on: June 25, 2014, 05:28:04 PM »
Mechanical fan, way more reliable than any electric junk.
« Reply #20 on: June 25, 2014, 08:34:40 PM »
Mechanical vs electric...  Mechanical always wins.  ::)
« Reply #21 on: July 17, 2014, 12:48:43 PM »
x 2, the man speaks the truth
