Author Topic: Anyone Run an Electric Fan successfully?  (Read 4996 times)
Offline Jrama
« on: June 20, 2014, 01:51:16 PM »
I have gone through 3 Taurus fans, as soon as they get muddy its begins a slow and intermittent death of the fan. Get them Muddy again its game over...
I like the electric fans as they are easier on the motor and can be switched off etc etc Anyone have advice on mud-proofing?
Otherwise its back to a mechanical fan
Offline GreenBstrd
  • '96 XJ - 4.5" R.E. lift - 33"BFG AT
Re: Anyone Run an Electric Fan successfully?
« Reply #1 on: June 20, 2014, 02:51:52 PM »
Have you tried coating the fan motor, and any open connections with dielectric grease? That's what I did with mine, and I haven't had any problems yet. Sunday will be the real test though.
Offline apeman
  • not as grumpy
« Reply #2 on: June 20, 2014, 06:49:46 PM »
I ran a 97+ zj fan on a switch for years, without problems. They're easy to come across , 4 bolt install and a simple plug n play. Taurus fans burn up easy and aren't meant to get grimy and wet.
Getting grumpier every day.
Offline Jrama
« Reply #3 on: June 20, 2014, 08:59:28 PM »
But does it fit a TJ?
« Reply #4 on: June 20, 2014, 10:54:32 PM »
Jamal, I ran a Taurus fan twice in 2 different off-road vehicles and managed to keep them alive . I found that mud would pack onto them and dry-up causing an imbalance whenever I used them , thus shortening their lifespan. I went to a hardware store and put that mesh screen that is used on doors in front of the fans. It really helped keep big clods of mud from adhering to them. Give it a shot should you run an electric fan again.
HTH
« Reply #5 on: June 21, 2014, 12:35:59 AM »
JAmal I have a fan kicking Around d if you want a spare
Offline Jrama
« Reply #6 on: June 21, 2014, 04:23:27 PM »
Ended up installing a mechanical fan
Offline pooljunky
« Reply #7 on: June 21, 2014, 06:09:37 PM »
Hey jack.. I'd take that off of you
« Reply #8 on: June 24, 2014, 08:35:39 AM »
Are you sure about this? The only ZJ I know of that came with an electric fan is the 1998 with the 5.9L package and those are pretty rare.
Did you mean '99 and up WJs?
« Reply #9 on: June 24, 2014, 08:42:50 AM »
I've been running a Taurus fan for a few years now. Its problematic at best.  The first couple I got from the wrecker went bad quickly and took some wiring with it. Then my alt died and while you can usually drive quite  ahile just on the batteries the fan sucked the batteries down pretty fast, yes I said batteries(plural). They have a huge draw so the wiring and relay has to be HD. A simple 30 amp bosch relay isn't going to cut it.  Now my controller is acting up and probably needs replacing. Also the engine overheats when running hilly terrain in hot waether at high speeds(80km/h+).
Upside is engine stays nice and cool when putting along in 4low with RPMs low.
I don't think I'd do it again. I've never been in water deep enough to need to turn it off and I think I'd get better cooling from a better rad with the mechanical fan.
Offline JohnB
« Reply #10 on: June 24, 2014, 10:15:27 AM »
Really.  I've had the same Taurus fan for 10 years without a problem.  Water and mud over the hood every time I'm out.  You should turn the fan off before a crossing.  What are you using to control it?  Is it behind the rad or in front?
Offline Dingleberry
« Reply #11 on: June 24, 2014, 11:04:18 AM »
I had my taurus fan quit on me, going to replace it with another taurus fan. This time however, I will be coating the replacement fan with NeverWet from Home Depot. That stuff is miraculous! I used it on my rad one time and it kept all the fins free of clogging up with mud for an entire weekend in fisher east, and then some. Great stuff, use it on the alternator and distributor cap too!
Also, I use a bosch 30 amp relay for the fan, haven't had a problem with that. Its just the mud that killed the fan.
Offline dubbleJs
« Reply #12 on: June 24, 2014, 05:24:15 PM »
I attempted to fit a Taurus fan but with my alternator up top  the belt was in the way of the fan motor and I gave up. Instead I installed two 97+ XJ fans on switches and have not had any issues. It runs below 100. I ditched the a/c condenser that was blocking flow in front of the rad, keep the rad clean and always have the fans running (except for water crossings, but I usually forget to turn them off anyways  :P )
Offline BUKI
  • Project Fugly
Re: Re: Re: Anyone Run an Electric Fan successfully?
« Reply #13 on: June 24, 2014, 08:44:50 PM »
that's a great idea
Sent from my Nexus 5 using Tapatalk
« Reply #14 on: June 24, 2014, 09:18:43 PM »
Flex-a-lite... Not cheap but works very well... There are a lot of generic electric fans out there too. Spal, Be Cool, flowkooler... Google their websites and find a fan with high CFM's.
