Author Topic: tj doors stuck  (Read 2300 times)
Offline JPuchyr
tj doors stuck
« on: June 28, 2014, 09:55:43 AM »
Help... ;)
I can't seem to get my doors off.
Removed the 4 nuts, but lifting the door won't budge.
Any. Suggestions?
Re: tj doors stuck
« Reply #1 on: June 28, 2014, 10:12:40 AM »
Lube, jack-all and 2x4.
Re: tj doors stuck
« Reply #2 on: June 28, 2014, 10:59:16 AM »
That is your answer to everything.
Offline rws
  • Stump Grinder
Re: tj doors stuck
« Reply #3 on: June 28, 2014, 02:54:29 PM »
Beware that your door may hit the ceiling! ;D
Offline JPuchyr
Re: tj doors stuck
« Reply #4 on: June 28, 2014, 06:35:02 PM »
Thanks for the advice...
Anyone got a jacks-all I can borrow? ;)
 I can provide the lube and 2x4 ... why does that sound dirty?  :o
Re: tj doors stuck
« Reply #5 on: June 28, 2014, 07:20:31 PM »
Because Kevin said it.
Offline scott slade
  • Amboy... Route 66
Re: tj doors stuck
« Reply #6 on: June 28, 2014, 09:30:09 PM »
If you are around the NW, you can swing by and use my jack to get your doors off....  yes that does sound "dirty"...   Once you take the doors off a few times it becomes easier to remove them.  drop me a line, takes no time...
2005 LJ, Six Speed,
 16" Moab Rims
Offline rws
  • Stump Grinder
Re: tj doors stuck
« Reply #7 on: June 29, 2014, 04:27:07 PM »
Floor jack with a piece of wood works good also.
Offline JPuchyr
Re: tj doors stuck
« Reply #8 on: July 06, 2014, 07:31:30 PM »
Thanks for all the advice, floor jack and a stack of 2x4s worked....
worked too well on the passenger, door popped out and fell on the floor, denting the lower corner :(
Ah well, excuse for a new paint job
Offline 03Jeeper
Re: tj doors stuck
« Reply #9 on: July 07, 2014, 02:57:25 PM »
Same thing happened to me...  :D
Offline JENSSEN
    • Racing For The Cure
Re: tj doors stuck
« Reply #10 on: July 07, 2014, 07:33:15 PM »
www.racingforthecure.ca
