Author Topic: 90 cherokee fuel ballast resistor problem ?  (Read 2689 times)
Offline blackcherekee
« on: August 08, 2014, 11:49:30 PM »
I think I may have a problem with my fuel ballast resistor my jeep starts and idles fine and drives fine until it gets hot then it loses all power. Any body else have/or had the same issue?
Offline Sean778
Re: 90 cherokee fuel ballast resistor problem ?
« Reply #1 on: August 09, 2014, 09:01:02 AM »
Have you tried bypassing the resistor when it's hot to see if it makes a difference?
'89 XJ
Offline ARBXJ
« Reply #2 on: August 09, 2014, 08:19:43 PM »
http://www.pirate4x4.com/tech/billavista/PDFs/Jeep_Renix_Fuel_Injection_manual.pdf
I an no mechanic but somewhere in this reference manual lies your answer. I have a 1990 but haven't run across this problem. Given it runs and then shuts down when hot, it is probably some kind of resistor related issue. Check the primary and secondary resistance across the coil? Are all the electrical contacts clean and soldered? This was a problem with the Renix system-contacts gunked up? Let me know if this doesn't download and hope the manual helps more than my comments, regards ARBXJ
« Reply #3 on: August 10, 2014, 06:49:47 PM »
Remove the wires from the resistor and splice them directly together. The resistor was added to cut down the noise the fuel pump makes. It wasn't even used on earlier models but was added in later as customers complained about noisy pumps.
« Reply #4 on: August 11, 2014, 01:06:20 PM »
So I have spliced the wires and still no luck I'm thinking maybe it's the thermostat
Offline dubbleJs
« Reply #5 on: August 11, 2014, 02:22:34 PM »
Does it overheat? Or by 'hot' do you mean running temperature?
« Reply #6 on: August 11, 2014, 02:45:23 PM »
When it hits running temperature
« Reply #7 on: August 11, 2014, 03:31:27 PM »
Why do you suspect the ballast resistor? Or do you have low fuel pressure?
Offline smacd11
« Reply #8 on: September 02, 2014, 11:19:26 AM »
Did you get this solved?  My '89 was acting like that last year.  I too suspected fuel pressure problems, tested it - ok.  Replaced crankshaft position sensor - fixed.
