Author Topic: Price for cutting and programming a sentry key in Calgary?  (Read 1602 times)
Offline renguomin
« on: September 07, 2014, 06:23:10 PM »
I lost 1 key :'( and I don't know the 4 digit pin code. How much do i need to get another one here in Calgary?
Re: Price for cutting and programming a sentry key in Calgary?
« Reply #1 on: September 07, 2014, 07:39:37 PM »
I used a locksmith in Innisfail, but for the life of me I can't find his contact info.
He had all the computer programs, obd hookups and everything to program it for a 2002 Liberty we had, programmed right own to the glass hatch button.
Soooooooo....call around and check.  It was worth the calling around.
« Reply #2 on: September 07, 2014, 08:40:41 PM »
Budget Locksmith in the NE has all the equipment and typically charge $100.00 to make a second key. Be aware that there are two ways to do it and the proper way is to make a second key. Some places will simply make a clone of your first key.
Now, this may not sound significant but if you have a proper second key made you can program a third key by yourself with nothing more than the first and second key. If you have a cloned key, the computer simply thinks you are trying to program a key without two original keys and will not allow programming of a third key.
FWIW, if you have AMA Plus, the lockout service covers up to $100.00 in the event you lose a key, I have now used this service twice at the above locksmith and both time AMA covered the new key. He did say they only cover it if you lose a key and not if you bought a vehicle with only one key.
