Author Topic: Injector circuit malfunction  (Read 1935 times)
sgo70
« on: June 21, 2006, 02:01:12 PM »
Thats what the car reader told me??? As well as cylinder 4 misfire???
Are these related to an O2 sensor. Looked it up in the Haynes manuel and didn't find the " how-to " fix I was lookin' for. :shock:
Any input would be great.
Thanks.
« Reply #1 on: June 21, 2006, 02:11:45 PM »
Read through the trouble shooting section on how to test injectors.
Involes testing the voltage being supplied to the injector itself.
From there you will be able to whittle it down to wiring or the injector itself.
My bet is that its a bad injector, but you will have to test it all out to be sure.
sgo70
« Reply #2 on: June 21, 2006, 02:13:09 PM »
sounds hard, I'll be back in three days :shock: .
« Reply #3 on: June 21, 2006, 02:19:36 PM »
Quote from: "sgo70"
 :D  :D
Not at all. You just hook up a  tester to the wires that go to the injector. Turn it over and take the readings.
The haynes manual will have numbers that are in spec. Just carry on from there.
You have a misfire code because of the injector code. Meaning the injector is not working.
Unless you have physically damage the connection at one time or another, the more common problem is a bad injector, and they are not hard to change.
You can do it the long way.
Switch two injectors around
Hard reset computer
Search for codes again
Same codes same cylinder = bad connector
Same codes, switched cyclinder = bad injector
But the haynes trouble shooting should get you the same answer without the switching stuff around.
hth
sgo70
« Reply #4 on: June 21, 2006, 08:31:41 PM »
thanks
sgo70
« Reply #5 on: July 07, 2006, 06:37:29 PM »
O.k. I finally got off my arse and took a shot at this, I pulled the injectors off and swapped the suspect one over to another cylinder. I started it up and it ran few a minute or so until the number six started leaking fuel. After deciding I can't push it far enough away from my garage to just let it burn, I shut it down. When I pulled the injector out I noticed I sliced an o-ring. This is really getting fun!!! So now does anyone know where to get an o-ring kit? I couldn't find anyone with a new inj. in stock either. HELP! :x  :x  :x
SGO.
HIWYH8R
« Reply #6 on: July 07, 2006, 11:41:45 PM »
Just go to Napa and get an injector o-ring. Almost all makes of cars and injectors all use the same o-ring, which will work on yours. Also grease the o-ring on the injector and the hole you slide the injector into so it will slide in easy.
sgo70
« Reply #7 on: July 08, 2006, 10:27:54 AM »
ok I just found the most outrageously priced item in the world!
Had a hard time finding the new o-rings so I went to the dealer near my house. I called ahead and he said he had a kit for $25, so I go down and of course it wasn't there, so the guy searched around and found another one that should fit. Now I don't blame the guy for anything, he was quite helpful, so he brings me this "kit". It consists of, get this, ONE O-RING for $25.00!!! So I took it, right in the you know what, no grease or warning! :x  :x I'll be a little more careful putting these in I guess.
sgo70
« Reply #8 on: July 09, 2006, 11:44:46 AM »
Weel I swapped injectors and the problem showed up on number 1 now. Pretty sure a new injector is required, thanks for your help.
