Author Topic: HELP: HAve a 06 Commander 5.7, engine blown, need advice about swap  (Read 1475 times)
Offline caar
Hi All,
Has anybody removed a 5.7 engine from a Jeep commander?
My engine is blown and I have a replacement already.
I have taken apart the whole front , but I don't know where to start to remove the engine.
does anybody  have a written procedure of how to remove it?
i really don't want to take it out from underneath as the Haynes manual recommends.
if somebody wants to make some bucks and remove it from me also let me know.   I have all the tools and a heated garage.
thx
CArlos
Carlos
96 XJ, 33s, Winch
85 VW-Bombardier Iltis (Typ 183)
Offline jk8
Re: HELP: HAve a 06 Commander 5.7, engine blown, need advice about swap
« Reply #1 on: November 11, 2014, 06:21:02 AM »
Its not all that hard to drop it out below! I'd do the research...theres only 8-10 bolts holding,in that rail....plus engine and granny disconnection.
« Reply #2 on: November 13, 2014, 06:31:38 PM »
If Haynes recommends you drop it out below it might be your best option... Basically, just mark every hose and wire with tape and a number and disconnect everything going from the engine into the cab. Then undo the bolts on your bell housing, your exhaust manifold, motor mounts, and anything else thats holding it from coming out the top with a lift and your set...
