Author Topic: Clutch  (Read 1537 times)
Offline MOABICON
  • MOABICON
Clutch
« on: November 23, 2014, 08:55:50 AM »
What clutch, pressure plate, release bearing, pilot        bearing set do you recommend? Where in Calgary        do you buy them? Could use the pivot ball & spring too.
**2003 Jeep TJ Sahara, 4.0 litre
Offline Black Betty
Re: Clutch
« Reply #1 on: November 23, 2014, 09:06:22 AM »
Apparently the Luk clutch is the same as the factory clutch, but much cheaper.
Talk to Dave down at broken axle.
Stupid hurts
Re: Clutch
« Reply #2 on: November 23, 2014, 09:10:23 AM »
Most aftermarket companies that offer a stock replacement clutch kit will work fine, auto value/napa/parts source. I would recommend a new flywheel as well, they aren't expensive and better then machining your current flywheel. The pivot ball and spring I've only found through the dealer, but they are cheap.
If you want a fancy clutch kit we have done a few center force kits that offer better holding power with a slightly stiffer pedal feel, which I prefer because tjs have a very light pedal after new parts are installed.
