Author Topic: Wiring issue  (Read 1845 times)
Offline newfiewheeler
Wiring issue
« on: December 03, 2014, 04:46:43 PM »
So I seem to be having a wiring issue and after replacing the old deck, it still is happening.
Whenever I turn on the radio, after a couple minutes the gauge cluster and the radio loose power. If I turn the radio off, the gauges will eventually start to work again.
Any ideas what could be causing this?
Re: Wiring issue
« Reply #1 on: December 03, 2014, 09:09:20 PM »
Does it matter if the headlights(dash lights) are on or off?
Re: Wiring issue
« Reply #2 on: December 03, 2014, 09:56:30 PM »
no it doesn't. i left work and drove for about 10 minutes before it cut out this time. if i turn off the deck, the gauges work fine. i checked the iod fuse and its fine.
Offline Teeka
Re: Wiring issue
« Reply #3 on: December 03, 2014, 10:11:38 PM »
It say no bus?
Re: Wiring issue
« Reply #4 on: December 04, 2014, 12:24:29 PM »
Not sure what you mean by " it say no bus"?
Offline jkrubi
Re: Wiring issue
« Reply #5 on: December 04, 2014, 12:56:37 PM »
What jeep do you have? " no bus" is a jk thing as it loses it canbus, and the radio is part of that system, or at least it talk to something thru it.
How did you install the new radio? An adaptor plug to wiring? Or did you choose your own wires to tap into? What else did you out in at the same time, amp?
Re: Wiring issue
« Reply #6 on: December 04, 2014, 05:26:00 PM »
i should of mentioned, its a 99xj. no codes, wiring seems to be right but I'm gonna pull it apart this weekend and double check.
