Author Topic: FIXED - Jeep won't start, Fire and fuel are good.  (Read 3598 times)
Offline jandh
« on: January 07, 2015, 09:01:40 PM »
Anyone have any idea's to try? I'm at a loss here.
Jeep started running a little rough, like it was missing and also started to smell rich. this got progressively worse over driving it 4 or 5 times over a 4 month period.
Last night it was running rich and backfiring ever time i reved it up while driving. finally while idling in my driveway it stalled and will not start at all.
-It has good gas and is getting fuel not only on the rail pressure but we even pulled the injectors and watched them spraying in order.
-it has good spark and new plugs
-Replaced the coil
-Cap and rotor are new and cleaned, along with plug wires.
-turns over just fine
-throttle body clean
-Battery good and charged
-air filter removed and still with tons of air, gas and fire. no starting.
-Vacuum lines checked
-Throttle sensor has a good strong 5V going to it, so no short.
-Compression is 1-120, 2-100, 3-120, 4-100, 5-120, 6-110
Will occasionally backfire lightly through the throttle body, but not often.
Is constantly flooding because it won't start.
I feel almost defeated here. Gas, air and fire make combustion, so what the F#^% am I missing??
Mileage is 192xxx KMS
May only guesses left are:
Timing chain - but if it's broke wouldn't the rotor not turn?
Map sensor
CPU
drive gear on distributior
« Last Edit: January 09, 2015, 08:43:35 AM by jandh »
1991 YJ
Offline pooljunky
Re: Jeep won't start, Fire and fuel are good.
« Reply #1 on: January 07, 2015, 09:44:34 PM »
TPS sensor or I think I want to say crank sensor..  the one that bolts to the bellhousing
« Last Edit: January 07, 2015, 09:46:20 PM by pooljunky »
Offline jandh
« Reply #2 on: January 07, 2015, 09:48:33 PM »
It's reading 5v from the plug and 5v once plugged in, usually when a sensor fails it shorts the contacts when powered.  However weirder things have happened since I've seen coil that fire still not be good.
I'm going to try to find a replacement just to ease my mind.
When the bell housing Crank sensor is done, doesn't that eliminate fire completely?
1991 YJ
« Reply #3 on: January 07, 2015, 09:57:10 PM »
CPS. Replace it. Weird things happen when they start to fail. Also have had similar symptoms from a bad coil. But I would do the CPS first.
Offline jandh
« Reply #4 on: January 07, 2015, 11:17:49 PM »
CPS has that much control eh? well that will be the next sensor I will deal with.
The coil was replaced tonight, not a difference at all.
1991 YJ
Offline pooljunky
« Reply #5 on: January 08, 2015, 12:45:28 AM »
I have a few of those somewhere.... where? good question lol
Offline BUKI
  • Project Fugly
Re:
« Reply #6 on: January 08, 2015, 08:56:07 AM »
I'd think timing??
But it'd probably backfire turning over.
Offline jandh
« Reply #7 on: January 08, 2015, 06:14:01 PM »
Thanks all, checked the timing today, dead on.
Problem was 6 completely fouled plugs...   Must have been bad gas to foul 6 new plugs within an hour of run time. Changed out all 6 and bam fired right up. Even though the original plugs had spark, it must have been to weak.
Thank you all for your help
1991 YJ
« Reply #8 on: January 08, 2015, 07:31:51 PM »
did you use the Champion copper plugs?
thats weird to could 6 plugs that fast and together.
Offline ornamental
« Reply #9 on: January 08, 2015, 08:03:23 PM »
I had a similar issue,  the plugs were wet from being flooded.....  Needed cps and coil also.
« Reply #10 on: January 08, 2015, 08:54:31 PM »
I think that may be your problem.....
Offline jandh
« Reply #11 on: January 09, 2015, 08:42:18 AM »
Yes the Champion copper plugs were the ones that went bad. Ive never used another plug in my life.
Until yesterday that is.
1991 YJ
