Author Topic: Can i swap yokes?  (Read 1223 times)
Offline Marco
Can i swap yokes?
« on: January 26, 2015, 11:19:47 AM »
Morning, I have replaced transfer case from a cherokee into my TJ. Everything is good except front driveshaft. Can i take the yoke on front output shaft off and swap it with a yoke from a TJ transfer case so the driveshaft will work? If i can does anybody have one i can buy? Thank you for any insight.
2000 TJ Sahara, 4.0L 5 SPD. dana 30/35's
locked and loaded
Offline AV.NINE
Re: Can i swap yokes?
« Reply #1 on: January 26, 2015, 11:24:05 AM »
Yes.
« Reply #2 on: January 26, 2015, 05:02:03 PM »
Should be able to take the yoke of your old t-case. Was the xj t-case indexed? The tj case sits a little higher in the front output. Not hard to do.
