Author Topic: top bellhousing bolts on jeep YJ/wrangler  (Read 2114 times)
« on: February 12, 2015, 12:42:32 PM »
instead of putting the reverse torx back in i'm going to use real bolts.
having a brainfart though. if i recall it is a normal 3/8" bolt 1 3/4" long correct?
Re: top bellhousing bolts on jeep YJ/wrangler
« Reply #1 on: February 12, 2015, 12:54:20 PM »
I thought it was 3/8-16 x 1-1/2 in my 05 TJ with the 6 spd
« Reply #2 on: February 12, 2015, 01:30:17 PM »
right. 3/8" 16thread.   those bastards were in there so tight i needed to use a breaker bar to get em undone.
Offline Grease Nipple
« Reply #3 on: February 12, 2015, 04:51:22 PM »
Yes, but you left out the part that you needed the breakerbar after you were turning the wrench the wrong way.
« Reply #4 on: February 12, 2015, 07:15:54 PM »
Jackstand Johnny strikes again! Rehehehehe...;)
« Reply #5 on: February 17, 2015, 01:08:27 PM »
Straight shot with an impact if you let the tail hang down.
« Reply #6 on: February 20, 2015, 09:51:59 AM »
ians just being funny,
but i did have to put my lil' breaker on it.  just an awkward position couldn't get any leverage.  popped them out, replaced with the proper bolts so next time the slave cylinder craps the bed it won't be that much of a hassle.
