Author Topic: 98 cherokee xj steering wheel column knock  (Read 1393 times)
Offline anjoxj98
« on: March 11, 2015, 12:38:25 PM »
Hello guys,
As I mentioned I have a 98 cherokee xj.
 The steering wheel column is knocking and is driving me crazy. I guess is a bearing inside the column or something.
I was wondering if I have to replace the column or is something that it can be fix and how to fix it .
Thank you in advance
Re: 98 cherokee xj steering wheel column knock
« Reply #1 on: March 11, 2015, 12:47:41 PM »
Google gm tilt steering wheel fix. Easy to do. Takes time. It is the ujoint in the column that comes apart usually.
« Reply #2 on: March 11, 2015, 03:54:57 PM »
I doubt the. 98 would have the GM column.
That being said, my 05 TJ has a slight knock in the column and I believe I tracked it down to the pillow block support, there us a slight amount of radial play in it.
