Author Topic: Hydraulic clutch conversion on a 1981 jeep cj7 with 4.2 L and a T5 trans  (Read 2659 times)
Offline bdron
I am wanting to convert my clutch to a hydraulic system and I wonder if anyone else on here has done it and what all I would need to do the change over on my 1981 cj7. I do have a master clutch cylinder and pedals from a 1987 yj if that helps me. Please let me know if you could tell me if there is a way that I can do it.
Brian
That will take some research. Easiest thing to do would be to call Advance, and or Novak and ask if they have done it.
Advance does a nice slave kit used for most universal installs.
From there you would need to source, or build the bracket to mount the slave.
Found it. I've used this one a few times. Once on my 4500 swap, and once on a ford T18 into a CJ behind a Golan Stroker.
http://www.advanceadapters.com/products/716331--jeep-iron-duke-slave-cylinder-kit/
Oh, and here is a good thread on it from Jeep Forum. Guys are using the iron duke 4 cylinder stuff and seem to be having success with it. Essentially the same thing I linked, but should be cheaper through local part stores knowing the application to ask for.
http://www.jeepforum.com/forum/f8/hydraulic-clutch-conversion-1156237/
Went ahead and found the parts at rock auto
Here is a dorman master. Middle price at 36$
http://www.rockauto.com/catalog/moreinfo.php?pk=964287&cc=1180842&jnid=423&jpid=2
And here is a LUK Slave. Mddle priced at 25$
http://www.rockauto.com/catalog/moreinfo.php?pk=4696611&cc=1180842&jnid=424&jpid=3
Call local and see what they give you for prices.
The steel line you can build at Mopac for cheap.
Amc eagles used a 4.2l and T5 with a hydraulic clutch. Napa still lists a slave  cylinder for around $30.
Offline bdron
Thank you guys very much.
I was able to order those parts and they will arrive this week some time. I will let you know how it works out.
