Author Topic: TJ Track Bar Issue.  (Read 1500 times)
Offline scott slade
  • Amboy... Route 66
TJ Track Bar Issue.
« on: April 09, 2015, 03:23:46 PM »
I have a JKS track bar on front of my LJ. Notice some noise and movement from bushing area on drivers side. Is this bushing changeable. ? It has a grease nibble on it. Jeep has two inch budget lift and track bar is an adjustable one. Thanks for any thoughts....
2005 LJ, Six Speed,
 16" Moab Rims
Re: TJ Track Bar Issue.
« Reply #1 on: April 09, 2015, 04:01:36 PM »
It is a currie jonny joint. Very replacable.  Does it have the aftermarket brace or the through bolt? Check the through bolt first. Sometimes they get wanked out there are two small  shims/clips in there as well.
Offline scott slade
  • Amboy... Route 66
« Reply #2 on: April 09, 2015, 08:01:57 PM »
Through bolt.  Maybe warn.?  Is that where I've seen the brace drilled round again and a bigger bolt put in..?
2005 LJ, Six Speed,
 16" Moab Rims
