Author Topic: parts xj  (Read 2088 times)
Offline Bovice
parts xj
« on: June 10, 2015, 09:10:40 AM »
Hey guys,
I found a good deal on a 2000 xj for parts. I have 2 96 xj just Wondering how comparable they are will body panels, doors, running gear swap over?
Offline Dingleberry
Re: parts xj
« Reply #1 on: June 10, 2015, 09:36:58 AM »
Almost everything will swap over fairly easily. Most body parts won't be an issue, except maybe hatch door/tail lights. Front clip is different style but I believe it would bolt-on. Doors should be straight bolt-on.
As for drivetrain, 2000 used distributor-less engines, that could be a pain to swap in to a 96 XJ. Also the automatic transmissions changed around '98 from a single-pulse per rev to 4-pulse per revolution. The tranny itself can be swapped over, you'd just need to keep the tailcone from your 96 auto and put that on the newer tranny, otherwise the thing will shift straight from 1st gear all the way through the gears into overdrive as soon as you get going over 10km/h.
Could you be a little more specific with exactly what you're wanting to swap over to your 96?
Offline Bovice
Re: parts xj
« Reply #2 on: June 10, 2015, 10:13:10 AM »
Awesome thank you. I only need the carpet and hood from it but wouldn't mind doors with full windows if they swapped over. Axles for spares ect
Re: parts xj
« Reply #3 on: June 10, 2015, 02:01:17 PM »
what are you doing with the rest of it
Offline Bovice
Re: parts xj
« Reply #4 on: June 11, 2015, 11:46:26 AM »
Was planning to throw it up on here for parts but buddy not getting back to me now so may not get it.
Re: parts xj
« Reply #5 on: June 11, 2015, 11:59:03 AM »
i think thats cause i was in the running too.
i'll text him and back out. tell him you want it.
i ran out of room for parts and vehicles.
