Author Topic: Keep/Ford Brake lines  (Read 4126 times)
Offline kemper
« on: June 24, 2015, 10:24:27 PM »
Hey guys,
Looking to put a 1978 Ford Dana 44 in the front of my WJ. I'm wondering if anyone has insight as to whether or not my stock brake lines will bolt up?
Re: Keep/Ford Brake lines
« Reply #1 on: June 25, 2015, 02:09:26 PM »
Doubt it
« Reply #2 on: June 25, 2015, 09:48:19 PM »
Seriously?
You're trying to put a '70s era 3/4ton truck axle thats setup for leaf springs into modern day luxury SUV.  Hooking up the brake lines is the easy part. Have you figured out what master cylinder to use since the stock one probably won't move enough fluid to properly work the brake calipers on that axle.
Might want to do some more thinking and research.
Offline kemper
« Reply #3 on: June 26, 2015, 11:39:00 AM »
Oh, dang. I thought it was a direct bolt in :(
Stock master cylinder is fine for this application as many cherokee guys run a WJ master cylinder for their 1 ton swaps.
Simple questions about brake line ends but I guess I'll just have to figure it out!
Offline dubbleJs
« Reply #4 on: June 26, 2015, 01:17:47 PM »
Yeah...as Clay said brake lines are just the tip of the iceberg. You will need to weld on coil spring buckets, control arm mounts, track bar mount, shock mounts, figure out a new driveshaft, make sure the gearing matches whatever rear diff you have...etc.
Wouldn't it be sweet if a d44 was a direct bolt in?!?
Offline kemper
« Reply #5 on: June 26, 2015, 02:29:21 PM »
Sorry man, I was being sarcastic. I'm doing full 44/60 swap. Axles are trussed, brackets welded, buckets welded, geared. All that's left is brake lines, new controls arms, and tires! I just can't find anything online about what brake lines are used and I'm still waiting on the calipers to come in!
Offline raf2379
« Reply #6 on: June 26, 2015, 06:43:21 PM »
I believe the banjo bolts are different, the ford D44 uses 3/8"-24 UNF - Long Banjo Bolt and the WJ I think uses a metric 10mm banjo bolt, only way to know (as I'm not that far yet in my build) is to check once your calipers come in, you might need to get new 3/8 banjo bolts, but be able to reuse your soft brake lines. or get new soft brake lines http://offroaddesign.com/catalog/braidedbrakelines.htm
« Reply #7 on: June 26, 2015, 11:31:48 PM »
I'm pretty certain greggs can build brake lines with whatever ends you ask them to use.
Offline kemper
« Reply #8 on: June 27, 2015, 12:45:41 AM »
The WJ actually uses a 3/8 -24 banjo bolt as well so it may work! Thanks for your response with legitimate insight into the matter! Are you building a WJ as well?
Offline raf2379
« Reply #9 on: June 27, 2015, 01:47:45 AM »
nope I'm building an XJ, its taking forever
Offline cjust
« Reply #10 on: June 27, 2015, 08:43:39 PM »
It's a monster of an xj
J ust
E mpty
E very
P ocket
