Author Topic: 1997 TJ to 1999 and up PCM swap . Possible ?  (Read 2151 times)
Offline Strongbad
« on: July 16, 2015, 04:25:49 PM »
Hoping you fine folks might have some insight on this topic.
Have a 97 4.0 TJ.  Want to put on a banks Sidewinder turbo, say's it only works with 1999 + TJ's due to the PCM.
Is it just as simple as pulling out the PCM from a 99 and throwing it in my 97 and flashing it ?
Thanks everyone !!
M
Offline dubbleJs
Re: 1997 TJ to 1999 and up PCM swap . Possible ?
« Reply #1 on: July 18, 2015, 10:16:30 PM »
I would research what differentiates the 99 pcm from the earlier years. I doubt it is as simple as plug and play...the harnesses not matching may be your first issue. Good luck, wish I could help more!
Offline pooljunky
« Reply #2 on: July 18, 2015, 10:20:53 PM »
you might have issues with the cluster. other than that..  My tj was a mix of alot of things.. but  didnt have much issues other than the cluster
« Reply #3 on: July 22, 2015, 01:59:51 PM »
Its going to depend on sensors and injectors. You will need to research which ones remained the same, and which ones changed.
Offline Strongbad
« Reply #4 on: August 18, 2015, 11:10:47 AM »
Really appreciate your help guys !
looks like it would be more trouble than it's worth.
may as well wait till the 4.0 gets tired, and shove a 350 in it.
