Author Topic: Gear pattern check  (Read 2333 times)
Offline LukeDuke
Gear pattern check
« on: July 22, 2015, 08:55:01 PM »
Doing the set up on my 14 bolt for the Jeepster.   0.006 backlash
How's it look? I think in pretty damn close
RDJP President
http://www.reddeerjeep.com/
Re: Gear pattern check
« Reply #1 on: July 23, 2015, 10:06:19 AM »
Need to see the backside. Driveside looks decent.
You can try going a few though either way to see if the contact will broaden out a bit. I suspect if you pull 2-4 thou out it will.
But if the backside looks good, the above pattern is definitely acceptable.
Offline LukeDuke
Gear pattern check
« Reply #2 on: July 23, 2015, 05:16:45 PM »
Here's the coast side. I have the smallest pinion shim in I have at 0.010. Next size it 0.014 and its to much.
RDJP President
Offline LukeDuke
« Reply #3 on: July 23, 2015, 05:17:35 PM »
RDJP President
« Reply #4 on: July 27, 2015, 12:40:43 PM »
If you've already tried the 14 and it goes bad than it looks like you are there.
