Author Topic: Comanche part out  (Read 2422 times)
Offline specialk
Comanche part out
« on: July 30, 2015, 01:50:03 PM »
Our Comanche was unfortunately in rollover a month ago.   The great news is that both my boys who were in the truck are fine with no injuries.   The bad news is that the beloved blue MJ is no longer.   So our loss could be your gain as the drivetrain is good, axles look good but need further inspection.
Everything is negotiable.  Deals on bundles.
1)   4.0l from a 95 Cherokee.  300K+ kms on it.   $250
2)   PCM from 95 Cherokee - $40
3)   AX15 5 speed transmission - $250
4)   Axles – would like to sell as set – $1800 - SOLD
5)    2 Bilstein 5125 Shocks – F4-BE5-A465-H7 - $75
6)   Comanche rear  drive shaft  - was shortened a small amount to work with the 8.25 - $100
7)   Front drive shaft  for XJ/MJ - $50  - SOLD
8-   Gas tank from short box - tank only - no sending unit $10
9)   Heavy duty tie rod – needs new ends. - $20
10)   2” (?) drop pitman arm - $20 - SOLD
11)   Clayton 3 link cross member (XJ/MJ)  -$250 - SOLD
12)   Complete driver and passenger door skins with handles and window cracks – gray – can even through in the newer door speakers -  $40
13)   2 rear MJ tail lights - $50  - SOLD
14)   2 front springs $20
15)   2 2”budget boost front coil spacers - $20
16)   5 – 33x12.5x17 Cooper  Discovery S/T  - $600 - SOLD
« Last Edit: August 31, 2015, 02:38:05 PM by specialk »
04 TJ Rubi
Offline JENSSEN
    • Racing For The Cure
Re: Comanche part out
« Reply #1 on: July 30, 2015, 04:04:09 PM »
How about a clean body? I have one sans drive train,...
how is the tail gate, rockers, cab corners,  bed? Pics of it now?
« Last Edit: July 30, 2015, 04:06:53 PM by JENSSEN »
www.racingforthecure.ca
Offline JackstandJohnny
  • where Jeeps go to die
« Reply #2 on: July 31, 2015, 08:15:17 AM »
time to get into a YJ..................... ;)
or a TJ?
Offline boggincj7
« Reply #3 on: August 04, 2015, 04:57:58 PM »
You got a pm. Thanks.
81 CJ7,304,waggy diffs,SOA,OBA,warn 8274,and always modifying.
Lethbridge Coulee Kruzers
« Reply #4 on: August 12, 2015, 09:51:32 AM »
is that drop pitman arm a bit more drop than a stock XJ/ZJ one?
or is it just a ZJ one?
if its a bit more than a ZJ one i'll take it
Offline reepr
  • Winch Wench
« Reply #5 on: August 14, 2015, 07:31:32 AM »
Pm'd on tires and rims
« Last Edit: August 14, 2015, 07:36:11 AM by reepr »
2011 ruby / 35 "stt/ metalcloak gamechanger
76 cj5 under revival
Offline specialk
« Reply #6 on: August 31, 2015, 02:38:18 PM »
Updated - BUMP
04 TJ Rubi
