Author Topic: who can rebuild JKS track bar.?  (Read 1745 times)
Offline scott slade
  • Amboy... Route 66
« on: August 18, 2015, 11:05:53 PM »
Going to pull my JKS adjustable track bar with the "johny joint".  Who can I take it to to get the joint rebuilt and new bushing at the other end.?
2005 LJ, Six Speed,
 16" Moab Rims
Offline AV.NINE
Re: who can rebuild JKS track bar.?
« Reply #1 on: August 19, 2015, 10:13:56 AM »
You should throw an EMF Joint in there. Never worry about it again.
« Reply #2 on: August 19, 2015, 11:16:55 AM »
X2 on emf. Should be stock bushing size at one end. North ridge probably has the currie rebuild parts in stock. Next day you should have parts. What mount do you have at frame end? Double shear mount or oem mount. If you have the oem mount it may have the vertical special bolt that comes with the jks track bar kit. You may need that bolt. Northridge should have those as well.
Offline scott slade
  • Amboy... Route 66
« Reply #3 on: August 19, 2015, 05:08:27 PM »
Cool.. stock mounts on both ends.. I will pull it this weekend.  Good to know it can be done.  Thanks gang...
2005 LJ, Six Speed,
 16" Moab Rims
