Author Topic: 05 LJ Led turn signal flasher.  (Read 3389 times)
Offline scott slade
  • Amboy... Route 66
« on: September 22, 2015, 03:58:16 PM »
Installed Led tail lights on the 05 LJ. Love em... will change front soon too. Turn signal is obviously doing the "hyper flash".  Is there a flasher relay ( 5 pin?) That will put the turn signals back to normal.?..  Who sells it.?   Looking for plug and play...
2005 LJ, Six Speed,
 16" Moab Rims
Offline CatSplat
Re: 05 LJ Led turn signal flasher.
« Reply #1 on: September 23, 2015, 11:21:52 AM »
You have a late TJ/LJ so you need a GCD-TJ0106 flasher for LED tails.
Jeep of Theseus
Offline scott slade
  • Amboy... Route 66
« Reply #2 on: September 24, 2015, 01:29:39 PM »
Yup... That's the part... Not sold in Canada.  It's a custom made item out of Oxnard California.  "Off Road" use only.   About $50.00  by the time it gets here....
2005 LJ, Six Speed,
 16" Moab Rims
Offline CatSplat
« Reply #3 on: September 24, 2015, 04:19:11 PM »
Yeah sadly it ain't cheap, but there's not much else you can do if you want your LEDs to work normally, as far as plug-and-play goes. Some guys have modified the stock module with a Radio Shack part and some wire, but there have been reports of that mod causing battery drain while parked.
Jeep of Theseus
« Reply #4 on: September 24, 2015, 07:39:11 PM »
What about the "heavy duty" flasher? That worked like a charm in my SJ
Offline scott slade
  • Amboy... Route 66
« Reply #5 on: September 24, 2015, 08:03:04 PM »
The "Radio Shack " mod seemed too scary,  also heard of fires.  I know the pre 2001 TJ led specific flasher works in the 05 but turn signals can stay on without the key in...  so yup... $50.00 for OE function.   But I love my lights...
2005 LJ, Six Speed,
 16" Moab Rims
Offline matthillhouse
« Reply #6 on: November 17, 2015, 09:11:47 AM »
Try bringing your flasher into auto value to look for a replacement. I modified my older TJ flasher, but when that crap the bed, I went to go find another one. It wasn't listed under TJ, but it was a heavy duty trailer flasher, exact same pins, and it was plug and play without having to be modified to prevent fast flash. And it was like 17 bucks.
Offline AV.NINE
« Reply #7 on: November 17, 2015, 09:21:21 AM »
I had purchased the LED flasher at Napa for my 02. They had it in stock.
Offline scott slade
  • Amboy... Route 66
« Reply #8 on: November 18, 2015, 11:11:50 PM »
Thanks guys, my last post on this was late September.  Ordered the modified one from California.  Works great. The 05/06 TJ's were quite unique in a lot of strange ways. ...
2005 LJ, Six Speed,
 16" Moab Rims
