Author Topic: Problem filling my gas tank.  (Read 2586 times)
HIWYH8R
« on: July 05, 2006, 10:43:15 PM »
Ok anyone come across this? After the long weekend I tried to put gas in my jeep and I now have to pump it very slowly or the pump clicks off. I took alot of rough gravel roads so something has shifted or blocked something inside the filler tube I'm assuming.
Offline apex
« Reply #1 on: July 06, 2006, 12:11:58 AM »
only problem i've enountered is the frequency of visits and cost per fillup.
oh that's right.... I drive a Jeep. should be expected.
does it pump fine if you pull the handle out a couple inches? it's the only way I can fill mine.
Some of our company trucks will not fill up at some older gas stations. Somethinga bout the pour spout and filler tube not liking each other.
HIWYH8R
« Reply #2 on: July 06, 2006, 12:26:20 AM »
Na, this is a new problem since the weekend. I always fill up at the same place and I'm having a problem now. Tried a couple different gas stations and same thing.
When I look down the filler pipe I see a plastic tube going down the middle. This is the vent tube when filling. I think something has moved or something??
Offline apex
« Reply #3 on: July 06, 2006, 08:41:03 AM »
check this link out.
I rememeber hearing about this a while ago. Might score you an extra 5 gallons if your yj is 91-95.
http://www.jedi.com/obiwan/jeep/15to20gal.html
HIWYH8R
« Reply #4 on: July 06, 2006, 07:49:00 PM »
Thanks Apex, that's probably where my problem lies. That tube probably got kinked somehow. I was thinking about that writeup but couldn't find it.
HIWYH8R
« Reply #5 on: July 08, 2006, 12:08:45 AM »
Problem fixed. Turns out it was the end of my jerry can plastic hose fell into the filler neck causing a resrtriction, Also while i had it apart I did the conversion only to find out I already had the 20 gallon option. Should have known before since I can put over 70 litres in  :oops:
Offline apex
« Reply #6 on: July 08, 2006, 12:28:07 AM »
HAHAHA  :D  :D  :D
too funny.
I got you beat. That "nasty" sound I was tell u about. T-case skid wasn't bolted up tight. Was rattling the spacers makin a wiked sound. Then my check engine light came on. Pulled the code P0455 - Major Leak in the Evap System. referenced my haynes and DC service manual, then cross referenced online... only to find out...  Please tighten your gas-cap. I got a good chuckle out of that. Felt like a bonehead 4sure.
HIWYH8R
« Reply #7 on: July 08, 2006, 12:38:25 AM »
Heheh, we get alot of the gas cap "errors" at work, but once you know you don't do it again
Hey did you have a little bit of water in your jeep this morning?  :D  :D  hehe
sgo70
« Reply #8 on: July 08, 2006, 12:50:52 AM »
I don't mean to jack your post, but I get that same error code about the leak. I even changed to a new gas cap cause I read some may be faulty. I've checked all the hoses in the system and still can't find anything but the code keeps coming back.
HIWYH8R
« Reply #9 on: July 08, 2006, 01:00:55 AM »
For those reocuring problems we hook up a smoke machine to the evap system and look where the smoke is coming out to see where the leak is.
Offline apex
« Reply #10 on: July 08, 2006, 10:10:59 AM »
ya... She was a little soaked when I tried to go to work yesterday. Had to pull the plugs just to keep the socks dry. At least everything is clean now!
SGO... check these out...s ee if there is aynthing that can help you.
http://www.car-groups.com/post/28429/Dreaded_P0442,_P0455_on_'02_TJ_Sport.html
http://www.wjjeeps.com/faultcodes.htm
http://www.jeepaholics.com/support/topic.asp?TOPIC_ID=37851
