Author Topic: reseting the engine light  (Read 2179 times)
Offline rossb
« on: July 25, 2006, 07:30:10 AM »
Anyone know how to reset the check engine light?  I have a thing that reads the error codes and sould reset them ... but apparently Chrysler has some problems in the 1996-2002 model year with ODB-II commands.  My Scan guage won't reset it.
Anyone ever try a scan guage?...it's a cool little device.  It is a trip computer, does diagnostics and gives you a digital readout from your engine.
http://www.scangauge.com/
« Reply #1 on: July 25, 2006, 08:08:53 AM »
Just pull the negative battery cable. That should reset things for you.
edit,
leave it off for 10 minutes
Offline rossb
« Reply #2 on: July 25, 2006, 07:50:01 PM »
thanks, that worked great...
Re: reseting the engine light
« Reply #3 on: July 26, 2006, 07:28:19 AM »
Quote from: "rossb"
I just ordered one and will report back once I receive and test it.
Vince
Offline rossb
« Reply #4 on: July 27, 2006, 09:00:10 AM »
I got one a few months ago so I could read the engine temperature, gas mileage etc on my motorhome.  It works great, tells you how much gas you are/have used...the gauge is great ...but watching the gas mileage on a motorhome is rather depressing...
« Reply #5 on: August 04, 2006, 07:18:47 AM »
I recieved the Scangauge a couple of days ago, definitely a neat little gadjet.
It seems to be able to do everything the cheap code readers can do and then lots more, for example, it will "freeze" the data when the vehicle throws a code. it can measure air intake temperature, engine load, TPS position, current and average mpg, current and max rpm, current and max coolant temp, current, max and average speed.
Another nice feature is the compact size and it goes from vehicle to vehicle easily.
Thanks for the link rossb, It was money well spent in my opinion.
Vince
streetvan1
« Reply #6 on: August 04, 2006, 07:33:26 PM »
Just curious, does that thing give you actual data from the sensors, such as o2 sensors and maf sensors? Or does it just give the filtered information such as codes and fuel economy?
