Author Topic: Rubicon electronic sway bar disconnect stopped working...  (Read 1755 times)
Offline GoChris
« on: October 04, 2020, 04:04:33 PM »
So, naturally I took the thing apart. After removing the bolts and starting to pry it apart, it started leaking water, that's not normal.
Oh, well that is quite a bit of mud where there shouldn't be mud.
Yuck, will need to clean all this out.
Yup, those are rusty.
Time for some wire wheel action, looks better now.
Then I greased it all up and put it back together, the gasket was good so I reused it. Forgot to take pics, but nothing exciting.
I confirmed the motor worked before I put it all back on the Jeep, that was a relief, as the replacements are not worth the cost, pretty sure they are over $1k.
Works now and the sway bar light stopped flashing, hurray! Time for more wheeling!
Re: Rubicon electronic sway bar disconnect stopped working...
« Reply #1 on: October 04, 2020, 05:16:17 PM »
Usually when these things get real bad most people delete them and use a manual version. Most tuners can shut the system off too so no flashing light.
Offline MattMan
« Reply #2 on: October 05, 2020, 08:37:16 AM »
So if the seals and gaskets are good then how’d all the water mud get in there?
MattMan
Offline GoChris
« Reply #3 on: October 05, 2020, 11:51:17 AM »
Ya, I didn't want to do that just yet, the cheapest alternative is cheapish, <$150, but puts the control is a somewhat awkward position to change. Other options are quite a bit more, like anti-rock for example. If the motor was toast then I would have evaluated options, but since it still works I'll keep using it.
Good question, I'm not sure. I did make it was tightened very well this time when I put it back together and greased it up a bunch which should hopefully help the seal? I might check it again after the next outing to see. There is no separate gasket on the motor side, just a rubber seal around it, also lightly greased that, probably should have done more.
« Last Edit: October 05, 2020, 11:53:01 AM by GoChris »
« Reply #4 on: October 05, 2020, 01:04:06 PM »
Well duh, the seals and gaskets are to keep the mud and water IN, not out🤪
Offline MattMan
« Reply #5 on: October 05, 2020, 06:32:34 PM »
Well… I stand corrected. They seem to be working very well then!  ;)
MattMan
Offline Sixty4X4
« Reply #6 on: December 08, 2020, 09:23:16 AM »
I would like to drill a grease nipple hole in mine and an opposing threaded plugged breather hole. That exploded view lets me know where to drill. Then it can be re-greased easy once a year. Used to do the same with factory plugs for my aero plane constant speed propeller.
2008 JKU Ruby, Jeep steel bumper, 9500 winch, 2016 5.3 Chev LT & 8L90 8 spd auto, 285 Maxxis Bighorns, MC 2.5" and LC Arms.
